0 Brake Squeek
Last Post: Tucsonmax1
Last Post: cazz1000
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Old 9th June 2009
scottsxl1200's Avatar
scottsxl1200 scottsxl1200 is offline
Other Motorcycle Model: Fatboy
scottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant future
Default Belt Replacement
Any idea on when to replace the drive belt? I heard a rider was thrown from their bike after a couple of teeth broke off their belt going down the highway.
I didnt say it was your fault, I said I was going to blame you!
Old 9th June 2009
Phaedrus's Avatar
Phaedrus Phaedrus is offline
Sounds like nonsense to me, belts do break, and quite a few have broken prematurely, usually when the bike is cold and put into gear. I would think a belt should last at least 30,000 k.
Here is some good bed time reading on the subject
http://xlforum.net/forums/s...ad.php?t=14871
Old 9th June 2009
brprider's Avatar
brprider brprider is offline
Sportster/Buell Model: Orange 1200R
brprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enough
Best advice I can give you is to check the condition and adjustment of your belt everytime you check your tire pressures. Unless you get a rock or something similar thrown up between the belt and sprocket, your belt should last for MANY thousands of miles. I've never had a problem with any of my belts. I'm on my 4th Harley.
I had a shaft drive come close to locking up on a Suzuki once. but that was a manufacturer's defect.
Everyday looks like a great day to play hooky.
I believe I'll start today...
Old 9th June 2009
Yup, sounds like BS.
Personally, I've never broken or had to replace a belt. I think that if you don't abuse em, keep em tensioned properly and inspect them for wear you'll be fine.
Old 9th June 2009
mrlowlight mrlowlight is offline
Sportster/Buell Model: XL 883R
Other Motorcycle Model: Moto Guzzi V750.
Other Motorcycle Year: 1988
mrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura aboutmrlowlight has a spectacular aura about
I've got 35,000 kliks on my bike and the belt looks as good as new.
www.mrlowlight.com
Old 9th June 2009
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
There are numerous threads on this subject, a few people have had repeated problems with belt breakage. The rest of us rarely if ever have a problem with it, even those of us pushing over 90 HP that repeatably do wheelies and burnouts. keep it adjusted properly (but not too tight) and you will probably never have a problem.
Old 9th June 2009
Oldwrench Oldwrench is offline
Sportster/Buell Model: Sportsters
Oldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the rough
Default Belt Life
Over 30,000 miles on mine, and I'm not gentle. I don't run on rocky roads, and I don't dump the clutch on a wet belt, like after washing.
Properly tensioned and barring rock or debris damage, these belts will easily go over 100,000 miles. All it takes is one rock caught between the belt and wheel sprocket to over-stress the belt. I don't ride in rocks.
Old 11th June 2009
Unix's Avatar
Unix Unix is offline
Sportster/Buell Model #2: Cyclone M2
Sportster/Buell Year #2: 2000
Unix is on a distinguished roadUnix is on a distinguished roadUnix is on a distinguished road
yup, not too long ago i was riding on a gravel road (caused by road works) about 60km/h... and for a split second i heard a harsh metallic sound - i believe a small rock got caught in the pulley. After inspecting it at home, i noticed a half of 1 tooth chipped away in the belt.
Old 28th October 2009
parentevan parentevan is offline
Sportster/Buell Model: 1200C 100th Anniversary E
parentevan is an unknown quantity at this point
Just finished installing Hi Comp pistons, Cams, intake, exhaust, and Thunderslide last month. Snapped a belt on Monday at just under 14k miles.
Old 29th October 2009
scooterbe883's Avatar
scooterbe883 scooterbe883 is offline
Sportster/Buell Model: 883c Sportster
Other Motorcycle Model: xl1200c
Other Motorcycle Year: 2011
scooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the roughscooterbe883 is a jewel in the rough
after reading my service manual, i dont see where a specific mileage is given. but it shows several conditions to watch for on the belt and describes whether to monitor or replace. basically, external tooth cracks, missing teeth, hook wear and stone damage..states to replace. hope this helps
