Last Post: r4fthrs
Last Post: cotton1
0 Clutch cable options
Last Post: BWP 5p
0 Diagnostic help
Last Post: BradX13
0 Not charging issue!
0 Value of a Boattail?
0 Brake Squeek
Last Post: seajay
0 Cylinder Piston kits
Last Post: seajay
0 how many miles are to many miles
Last Post: Turbo Sporty 48
0 Thinking of building a custom blast...
0 Vance and Hines Code:REaD
0 Head gaskets.
Last Post: cotton1
Last Post: hexnut
0 1988 106 inch build ( agent orange )
Last Post: Will1250
0 Won't rev past 1200
Last Post: Aocasio
0 z bars
Last Post: lucifer_mr2
Last Post: big andy
Old 11th June 2009
johnnyjellybean's Avatar
johnnyjellybean johnnyjellybean is offline
johnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished road
Default Buying another one! Who's using synthetic in an iron head and what weight?
I've owned 5 sportsters in my lifetime.... a 72 , 74, 76 , 77 (brand new) and a 79 (took it on a trade) and it looks like I'm getting a nice, clean, relatively unmolested 75 (converted back to right side shift) Is anyone using synthetics in sporties now and if so what weight?
1st post by the way !
Old 11th June 2009
mikefealk's Avatar
mikefealk mikefealk is offline
Sportster/Buell Model: '75 hardtail
Sportster/Buell Year: yes
Sportster/Buell Model #2: honda shadow
Sportster/Buell Year #2: 2000
Other Motorcycle Model: 1964 suzuki hill billy 80
mikefealk is on a distinguished roadmikefealk is on a distinguished road
welcome from spokane, washington. theres been quite a few threads about syn oil in ironheads. I believe the overall consenses was no thanks.
Old 11th June 2009
Welcome! to the Ironhead/XLForum.
Lots of recent talk about using straight 40/50/60 dino oils, depending on air temperature.
Old 11th June 2009
Sportster/Buell Year: 1972
Use fossil 50wt. in the engine, synthetic 20/50 in the trans.
Old 12th June 2009
They'll land up mixing a bit no? Isn't there a breather hole that vents pressure?
Old 12th June 2009
jpironhead jpironhead is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1979
jpironhead is on a distinguished roadjpironhead is on a distinguished road
I will pass along this advice from a very trusted master mechanic, master machininst, and land speed record holder (on an ironhead) who had about 30 years experience working on old-iron and I had the pleasure of studying under.
"I strongly discourage you from using synthetic in your ironhead. On a molecular level, synthetic oils are engineered with much smaller molecules than dino oils, which in turn makes them slicker. This allows the nonsealed older styles of bearings to skate inside of the races. This inturn causes heat and brinelling. If you want to get the most out of your bottom end, use dino. No blends. Straight 50w up to about 95 deg days then 60w."
As far as the primary....they make sportlube for that. Dig it.
Oh, that breather hole. My advice...plug it.
Old 12th June 2009
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
The old tale that synth causes rollers to skate has been proven myth long ago.
But synth in loose-clearanced old twins does rattle a lot and tend to burn a lot, this I found from experience. And synth in the gearbox of an Iron head I found makes the clutch slip.
Plug what breather hole? The bottom end and the gearbox both need to breathe.
Old 12th June 2009
gunterjaeger's Avatar
gunterjaeger gunterjaeger is offline
Sportster/Buell Year: 72
Sportster/Buell Model #2: Sporty
Sportster/Buell Year #2: 05
gunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of lightgunterjaeger is a glorious beacon of light
Plug the breather????? This almost sounds insane, but shit, thats where most of my oily mess is coming from. Can you really do this?
I'd rather die trying!
Old 12th June 2009
Hopper's Avatar
No you can't. Go to the techincal stickies index at the top of the forum and look up the Engine Breather 101 thread. It will explain what is causing the oily mess out your breather and how to fix it.
If you plug the crankcase breather, all that pressure will come out the next easiest place, usually a gasket or points seal etc. Plus it robs you of several horsepower as the lower end of the engine acts as a big air compressor.
Old 12th June 2009
Shadowdog500's Avatar
Shadowdog500 Shadowdog500 is offline
Sportster/Buell Model: XLH-1000
Other Motorcycle Model: Honda Spree
Other Motorcycle Year: 1987
Shadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enough
I think he means to plug the transver valve between the case and the primary. If it goes bad, and your bike wet sumps, allot if not all of the oil winds up in the primary. HD finally blocked it off perminentaly in '77. Last winter my '75 wet sumped and all of my oil wound up in the primary because it went through the transfer valve.
I would not plug the breather, as Hopper said, bad things would happen.
Chris
It’s not really your bike unless you work on it yourself!
"Believe nothing, no matter where you read it, or who said it,
no matter if I have said it, unless it agrees with your own
reason and your own common sense."
-Buddha (536 B.C.-483 B.C.)
