0 '89 Sportster 1200 Chopper
0 Bikes and Bells and Bears
0 Engine dies when choke off
0 rpm jump pulling in clutch
0 Value of a Boattail?
0 New to Harley
0 Curious as to what I actually have
Last Post: JakRabbit
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
0 79 ironhead
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 THE Trainspotting Thread
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
Last Post: tvon
Old 17th June 2009
brimic's Avatar
brimic brimic is offline
Sportster/Buell Year: 1990
Other Motorcycle Model: Fxdwg
Other Motorcycle Year: 98
brimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the rough
Default Weird sound when engine is hot
I noticed that somewhere in the top of the engine there is odd sound when the engine is hot. I notice it when I ride to work and back after about 20 miles or so. Sounds sort of like a handful of gravel swishing around in a coffee can.
Where do I start looking for the cause? Could it be a worn lifter or rocker?
TANSTAAFL
Old 17th June 2009
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
That sounds like it could be detonation, which would be very bad. What do your plugs look like, are they white or grey? Have you made any performance upgrades?
Old 17th June 2009
brimic's Avatar
Ah, I kind of had that thought in the back of my head but wasn't sure, I've been filling up with 93 octane on the last 2 fill-ups to see if that made the difference- it hasn't.
I didn't pull the plugs yet but will tonight.
Only upgrades I made was a free flowing air cleaner and exhaust along with carb mixture adjustment. I replaced all of the top-end gaskets this spring due to a blown head gasket, and rechecked the carb adjustment afterwards.
Old 17th June 2009
brimic's Avatar
I just looked at the plugs, they both look the same.
I "think" they look normal- a light gray ground electrode, the insulator and center electrode look almost new, and the rest of it has a bit of carbon fouling.
Old 17th June 2009
brimic's Avatar
I also hear this sound constantly, during acelleration/decelleration, and idling.
When I first heard it I thought it was my rear gas tank bolt coming loose again, but like I said, it doesn't make the noise until the engine is hot.
I'm also running Mobil1 Vtwin oil,not sure if that makes any difference or not. Bike just rolled over 15,000 miles yesterday.
Old 17th June 2009
Kwest187's Avatar
Kwest187 Kwest187 is offline
Sportster/Buell Model: 883/1200 standard XL
Sportster/Buell Year: MUTT
Kwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really nice
Any detonation I've had is more like a piercing ping...and usually happens when throttle is added and it doesn't really matter if the motor was hot or not...your described sound seems more like a bearing issue...and since it comes on when warm and the oil thins that would make sense...I don't want to freak you out though...your bike is a 1990 correct?
it could be many things and even though it sounds top end it could be from anywhere...the primary chain is where I'd look 1st...it could be loose or the shoe could be wearing out and the hot oil in there breaks down and your hearing the chain rub on the shoe bracket...
also if the sound "just started" and you didn't change timing or jetting or pipes...there is no reason for it to start detonating...but stranger things have happened-
So yeah-check the P-Chain and the if no clues there put a mechanics stetho or a screw driver on it while the sound is happening to try to zero in on it better-
Good luck
The horizon will never come into focus-but that doesn't keep me from trying.
Old 17th June 2009
Kwest187's Avatar
Is that a synth oil?
What were you running before...synth oils are lighter and bring a bunch of new sounds when you 1st switch that were muffled in the thicker oil before-
Old 17th June 2009
brimic's Avatar
I was running the H-D dino oil in it until this spring.
I'll take a listen to the primary chain tomorrow after work.
I'm familiar with what a bad bearing or pinging sounds like from car engines, not sure if that applies to bikes.
Old 17th June 2009
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of light
take a broom handle and put it to your ear. move it around to different locations. if you have a problem area you will hear it. I have a stethoscope for engines but its too loud, for me the stick works the best.
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
Old 17th June 2009
brimic's Avatar
I tried the screwdriver check last night though it probably didn't tell me much becasue I didn't have the engine hot, but the rear head, especially near the exhaust side was making the the gravelly grinding sound. I can't check it today, didn't ride it to work because we are expecting thunderstorms all day today.
