0 Head gaskets.
0 1967 XLCH stroker project
0 Stock 883 cold blooded
Last Post: oldboy
0 New to Harley
0 79 ironhead
0 THE Trainspotting Thread
0 rpm jump pulling in clutch
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
0 Value of a Boattail?
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
Last Post: jammantoo
Last Post: lugster
Old 18th June 2009
HooliganD's Avatar
HooliganD HooliganD is offline
Sportster/Buell Model: xl883/1200c
HooliganD is on a distinguished roadHooliganD is on a distinguished road
Default Dumb question... Where to drain oil?
I have owned several bikes in the past (this is my first harley, an 02) and have never had such a dumb question, but where do I drain the oil from? I see there is a drain plug for the primary but nothing for the engine oil. Nothing on the oil tank and I tried to follow the oil lines to see if there is adrain there with no luck.
I know, get the service manual. I can't afford one right now, I was laid off in march and the cheap haynes manual I have covers everything from back to the 70s and can't make anything out in the diagrams! Why can't I access the download section, how do I obtain that privledge? Damn it, I just want something to work out!
Old 18th June 2009
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
look at your swing arm. theres a rubber tube that bolts to it on the carb side. loosen the clamp and there she drains. after done put back on and fill tank. i then allways burp mine letting the air out and a bit of oil. recheck your oil and your good to go
edit to add its under up near where the arm pivots
the females are fixing my old XL for fathers day . its a ford not a harley but its mine, MINE !!!
Old 18th June 2009
Oldwrench Oldwrench is offline
Sportster/Buell Model: Sportsters
Oldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the rough
Default Oil Drain
The oil drain is a hose behind the engine/primary. One end goes to the oil line/tank and the other is clamped onto a stud on the frame. You get to it from the LH side. Undo the clamp, pull the hose off that stud and the oil comes out. Takes about 5 minutes for all the oil to dribble out. It is best to dump it when the oil is warm.
Old 18th June 2009
Default Addendum
Fill the new oil filter about 2/3 to 3/4 full of oil before you spin it on. Brings up oil pressure much faster that way.
Old 18th June 2009
tensejed's Avatar
yes i forgot to say that
Old 18th June 2009
tensejed's Avatar
where to drain oil?,
preferably not near a stream or lake or on mother earth.
oh man thats the 60s coming out of me
Old 18th June 2009
Secretblend's Avatar
Secretblend Secretblend is offline
Sportster/Buell Model: XL883L
Secretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to allSecretblend is a name known to all
Here are pictures of my oil change. Maybe it'll help.
http://xlforum.net/forums/s...d.php?t=493593
Old 18th June 2009
HooliganD's Avatar
Thanks so much folks, I saw that and wondered.
Old 18th June 2009
LOL, dude, why didn't you just email me...
Old 18th June 2009
HooliganD's Avatar
LOL, keV you were my fist thought but one, I've bugged you enough. And second I was stewing in my garage and posted this using my iPod and was hoping for an immeasuate answer.
Thanks everyone! Bike runs much quieter, for the canadians on here I used cdn tire's vtwin 20w50 dino oil.
Tomorrow I'll change the primary.
So how do I get permission to the downloads section? Do I have to show the secret stonecutter's hand shake?
