0 LePera Kickflip
Last Post: icebob
0 What's your helmet?
Last Post: Grymy
0 what do you think of these plugs?
0 A Day in the Life...
0 2016 48 Hesitating
Last Post: XLXR
0 'Idiot Lights' plastic face
Last Post: Edster
0 Cartridge Conversion?
Last Post: XLXR
0 Flirting with death
0 Tried to buy a new helmet
Last Post: kap
0 Tank swap
Last Post: Grymy
0 Oil Hose replacement help.
Last Post: McQueen
Old 21st June 2009
repo10851a repo10851a is offline
Sportster/Buell Model: xlch 1000
Sportster/Buell Year: 73
repo10851a is an unknown quantity at this point
Default what year is this frame
I have a frame with no vin on frame. It has a casting number on web by steering tube its a logo or something ''ME" and 47587-52A
then on engine top mount stay it has a looks like small logo MF then 47661-52
then at bottom near swingarm mount it has 47650 i can't see if there are more since I noticed after I put it together.
How can I figure out the year?
Old 21st June 2009
Picture? VIN? There are two basic frame styles, within those two groups there are many differences in brackets and such.
The numbers on the forgings mean nothing.
Old 21st June 2009
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
The year and month are located on the seat tab on the right side of the frame.
Read this.
http://reviews.ebay.com/Your-Sportst...00000003785806
