Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
Last Post: blindfredy
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
Last Post: sevenyears of famine
Last Post: friday
Old 30th April 2007
Torkil Torkil is offline
Torkil has a spectacular aura aboutTorkil has a spectacular aura aboutTorkil has a spectacular aura aboutTorkil has a spectacular aura aboutTorkil has a spectacular aura aboutTorkil has a spectacular aura aboutTorkil has a spectacular aura aboutTorkil has a spectacular aura about
Default Changed cams, now what?
Hi, yesterday i putted in Andrews n4 cams, i got cycle shack slip ons and k&n filter. the tends to have way more power, sometimes. but it seriously needs rejetting. I've tried some with the mixture, but isnt that only for the under 1/2 throttle?
I got 190 main (hd international, i know that that is more than most of the guys with hardcore modified engines, but that's stock for me)
would that make me need about 200main?
Would i need a new needle or so? how about one of those kits on ebay (heard much bad about them because of the pricing)
Thanks
Old 30th April 2007
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
What makes you think it's running lean?
Old 30th April 2007
in the exhaust when letting it just roll down hills and so, especially at high rpms, and about everything else in jetting 101 it does not run smooth at all (not that any harleys does, but i mean it runs variable through rpms and throttle)
Old 30th April 2007
biknut's Avatar
What do your spark plugs look like?
Old 30th April 2007
hmm, they did look brown to graish. ill go look now (havent checked after installing cams ) 1min
Old 30th April 2007
biknut's Avatar
I used to run those cams. They work real well. When I changed to them I didn't have to do much change to the jetting. One size bigger at the most. I was already stage one at the time.
Old 30th April 2007
Hmm, sounds good. but i havent jetted after going stage one
just dont get why my bike got 190 jet as stock, octane or fuel quality difference? Well anyway. thye look quite good. Lean wouldnt look any differnt from normal, would it?
Old 30th April 2007
not too good picture, but i would describe them as black with a gray (not from ash, but metal) "pin", where the spark goes. but this isnt accurate, i was testing it with chocke earlier, without running more than a couple of seconds. It runs a bit better with chocke too, i think.
Old 30th April 2007
Bruce's Avatar
Bruce Bruce is offline
Old Fart M/C Club
Sportster/Buell Model: 883/NRHS 1250 custom
Bruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud of
How many turns on your mixture screw, should be about 2-21/2 turns.
Ride safe!
Member of "The Cell #2"
Old 30th April 2007
Hmm, I am actually not sure all i know is that it was stock (i had to drill it) and i added 1 turn.
anyway, isnt the screw for lower throttle?
