Last Post: slojoe631
0 Riding music
Last Post: sprink
Last Post: ronccc
0 Xl???
Last Post: SD_Mike
Last Post: randy3934
Last Post: Greasyman
0 Mikuni - hangin revs
0 Now I did it. Feel my pain
0 old parts
0 Digital speedo from street bob on a sporty?
Last Post: yelladox
0 Starter for an XLCH
Last Post: Imaginearat
0 Hello from LA area
Last Post: initiatebjj
0 so it's officially ended
0 Oil not returning to tank
Last Post: 1Scooter
Last Post: Nicktater
Last Post: The Doctor71
0 blocked main jet air bleed screw
Last Post: RussW
0 Xr750
Last Post: seajay
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Randy_rots
0 Runs great - stalls on clutch pull
Last Post: tedcool
Last Post: FiftySixer
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
Old 1st July 2009
Default Xl Bearing Numbers
Lifted from Yahoo IHSG...
XL BEARING NUMBERS
8860 Steering Stem Neck Bearings (Qty 28) 1954 -1977 5/16” Diameter Loose Ball Bearings
8871 Nippondenso Starter Drive End Bearing 1991-1994 1200’s and 1995 to Present All Models NSK 6002VV
8876A Five Speed Mainshaft and Countershaft All 1991Split Plastic Caged Needle Bearings Torrington TORR2079 (??)
8877 Nippondenso Starter Drive End Drive 1981-1994 All Models NSK 6002ZZ
8878 Nippondenso Starter Commutator End Bearing 1981-1985 XL 1000’s and 1986-1994 XL 883’s NSK608ZZ
8882 Nippondenso Starter Commutator End Bearing 1986-1990 All Models Superceded OEM Number 8880 on 1/95 NSK 608VV
8883 Nippondenso Starter Bearing Commutator End Bearing 1991-1994 1200’s and 1995 to Present All Models NSK 608VV
8885 Clutch Pressure Plate Bearing Late 1984 to Present Ripan SS NTN 6208
8888 C/S Low Gear Late 1984 – 1990 Torrington B110
8977 Countershaft Tranny Case Needle Bearing 1991 to Present FAG BK2526 (Germany) or INA BK2526
8996 Clutch Gear Trapdoor Bearing 1991-to Present FAG 559197 (CANADA) or FAG 6209 C3
9007 Generator Drive End Bearing 1958-1981 FAG 6202-ZR C3 or SKF 6202Z
9008 Rear Wheel Bearing 1955 – 1978 Front Wheel 1954 – 1963 NTN6203Z C3
9009 Front Wheel 1954 – 1972 Rear Wheel 1963 – 1978 Fafnir 203KD
9010 Rear Wheel Bearing (Double Row Brake Side) 1954 – 1962 MRC 5203SBKF, or use 1-NSK 6203 & 1-NSK 6203Z
9025A Four Speed Clutch Trapdoor Bearing 1954 – 1990 NTN 6207ZZ, Fafnir 207KDD, NTN 6207Z
9052 Front Wheel Bearing 1973 to Present and Rear Wheel Bearing 1979 to Present Timken Race LM11949 & Timken Bearing LM11910
9057 Cam Needle Bearings Late 1958 – 1990 Torrington B-117
9062 Starter Motor Gear Housing 1967 – 1980 M8101 or INA BCE810
9063 Primary Cover Starter Shaft Needle Bearing 1967 – 1980 Torrington B1210, INA S1210 or IKO BA1210Z
9073 Clutch Pressure Plate bearing 1971- Early 1984 and Prestolite Starter Motor Drive End Bearing Fafnir S8NPP or NSK R12VV same as OEM 31539-66)
9088 Generator Commutator End Needle Bearing 1958 – 1981 INA BCE89
9118 Mainshaft Tranny Case Late 1984 – to Present Torrington BH2012
18534-29A Tappet Roller 1957 – to Present Japan BRV4146 EOIIKOG (??)
24648-77 Right Crankcase Pinion Shaft bearing 1977 – 1986 (EV) Torrington Bearing HJ202816
24729-52 Left Crankcase Shaft bearing 1954 – 1976 Timken Race 0719D and a Torrington Bearing RA52340-1 (??)
24729-74 left crankcase Sprocket Shaft bearing 1977 – 1990 Timken Race L44610 and Timken Bearing L44649
29916-82 Hitachi Generator Commutator End Bearing1982 - Early 1984 NSK 6201VV
29917-82 Hitachi Generator Drive End bearing 1982 – Early 1984 NSK (325) 604DU (??)
31539-66 Prestolite Starter Motor Drive End Bearing 1967 – 1980 Fafnir S8PP or NSK R12VV
31583-73 Hitachi Starter Motor Drive End Bearing 1974 – 1976 NSK 6004VV
35051-89 Mainshaft Fifth Drive Gear Needle Bearings 1991 to Present FAG HK2520
35960-54 Countershaft Closed End Needle Bearing 1954 – 1990 Torrington M-11121
35961-52 Countershaft Open End Needle Bearing 1954 – 1990 Torrington B-1212
36799-84 Clutch Basket Ball bearing Late 1984 – 1990 NTN 6089Z (??)
37722-52 Clutch Basket Needle Bearing 1954 – 1970 Torrington B-229
37722-71 Clutch Basket Ball Bearing 1971 – Early 1984 Fafnir 206KDD or NSK 6206ZZ
45586-78 Steering Stem Neck bearings 1978 – 1981 Timken Race L44610 and Timken Bearing L44640
47098-81 Right Side Swingarm Bearings 1982 to Present Timken Race LM11710 and Timken Bearing LM11749
47521-74 Swingarm Bearings Late 1974 – 1981 Timken Race 11520 and Timken Bearing 11590
47550-74 Swingarm Bearings Early 1974 and Earlier Timken Race 17520 and Timken Bearing 17580
48300-60 Steering Stem neck Bearings 1982 to Present Timken Bearing L44643 and Timken Race L44610
NOTES, ETC:
On NSK bearings: “V” = rubber seal on one side; “V V” = rubber seal on both sides; “Z” = steel shield on one side; “ZZ” = steel
shield on both sides; “DU” = heavy contact seal one side; “DDU” = heavy contact seal both sides.
“Heavy Contact” = higher drag. Normally the “V V” seal is sufficient.
I have never seen “DW” on an NSK bearing.
Ball bearing mfgrs. all use their own numbering system, although many of them are similar to each other.
Fafnir: “P” = rubber seal, “KD” = steel shield, etc.
SKF: “RS” = rubber seal, “Z” = steel shield, etc.
No suffix = no seal or shield
Seals retain grease & exclude contaminants. Shields do not – they need an auxiliary seal to do that. Often ball bearings that
are sealed or shielded on both sides are cheaper (because they are more common). You can safely pry out the seal/shield on
the side where it’s not needed. I’ve listed mostly double sealed/shielded bearings in the chart. The “C3” designation on some ball
bearings a clearance designation (the clearance, or “fit”, between the balls & the outer race). “C3” bearings are common (probably
the most common), and can be used in many applications.
Tapered roller bearing mfgrs. All use the same numbering system, although some use a “4T-” prefix.
AVOID CHINESE, TAIWANESE & EASTERN EUROPEAN BEARINGS LIKE THE PLAGUE. THEY ARE CHEAP,
BUT IN THE LONG RUN THEY ARE NOT INEXPENSIVE! GOOD BALL & ROLLER BEARINGS ARE NOT THAT
MUCH MONEY…..SPEND THE EXTRA & SAVE A LOT OF HEADACHES IN THE LONG RUN.
Some of the needle bearings in the list are obscure numbers & I left them alone
Old 20th May 2010
Shadowdog500's Avatar
Shadowdog500 Shadowdog500 is offline
Sportster/Buell Model: XLH-1000
Other Motorcycle Model: Honda Spree
Other Motorcycle Year: 1987
Shadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura about
Great list, Thanks! Rep given.
Chris
It’s not really your bike unless you work on it yourself!
"Believe nothing, no matter where you read it, or who said it,
no matter if I have said it, unless it agrees with your own
reason and your own common sense."
-Buddha (536 B.C.-483 B.C.)
Old 20th November 2010
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
Just curious to know if anyone is using this bearing (NDH 3206) for the clutch basket anymore. It seems that they are readily available, this is what is currently installed in my clutch basket. Anybody know if this is the OEM bearing?
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
asasial's Avatar
asasial asasial is offline
Sportster/Buell Model: 1200c 1980 chopped frame
Sportster/Buell Model #2: Ironhead chopper
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Nightster GF's Bike
Other Motorcycle Year: 2008
asasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to all
thanks for the info you have me a bearing number i had been wanting to cross to a sealed for quite sometime.
1979 Ironhead Chopper aka Home Wrecker
1995 1200 on a modified 1980 frame rigid mount swingarm
2008 Nightster GF's bike
Why buy parts, when you can pick up some tools and make something way cooler?
Old 21st November 2010
2007Low's Avatar
You're welcome, I just thought it was a little odd that it isn't listed in the bearing list here in the sticky. Do think this is the OEM bearing?
From the list here there are two other bearing numbers list for the 71 and later clutch basket. I was wondering if the one I have is maybe not as good as the ones listed in the sticky. Those two appear to be the double shielded type. I have not removed mine yet to see if it is also double shielded, definitely shielded on the exposed side.
2007Low's Avatar
Originally Posted by 2007Low View Post
You're welcome, I just thought it was a little odd that it isn't listed in the bearing list here in the sticky. Do you think this is the OEM bearing?
Bump
Old 16th May 2012
timberjack's Avatar
timberjack timberjack is offline
Sportster/Buell Year #2: 1973
Other Motorcycle Model: 2002 sporty heavy modded
timberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura about
I also got oem 35105-52 bearing race mainshaft, is the same as sku 96-281.
Old 9th June 2013
DDDDylan DDDDylan is offline
Sportster/Buell Model: XLS 1000
Sportster/Buell Year: 1979
Other Motorcycle Model: CB750
Other Motorcycle Year: 1995
DDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to allDDDDylan is a name known to all
"9007 Generator Drive End Bearing 1958-1981 FAG 6202-ZR C3 or SKF 6202Z"
I just found Napa carries this part as Napa Part # BRG 6202J for ~$16. The website lists it as Napa brand but it comes in an SKF/Napa box. This bearing contains eight balls instead of seven like some off-brands I have seen, and it comes in the open (not shielded/sealed) configuration like the original HD part.
1979 XLS, '76 Keihin butterfly carb, Ultima ignition, remote oil filter
Old 7th November 2017
http://xlforum.net/forums/s....php?t=2045726
From post #7:
9008= SKF 6203
9009 = SKF 203
Hazmat Life
Old 11th February 2018
Bwf347 Bwf347 is offline
Sportster/Buell Year: 1968
Other Motorcycle Model: FLHR
Other Motorcycle Year: 2002
Bwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud ofBwf347 has much to be proud of
Just want to give some credit. GA posting up these numbers has saved me lots of time trying to cross reference.
Sure with the part numbers Taiwaiin and Chinese junk is easy to find on JP or eBay but cross referencing is another animal. Thanks GA
