0 C.O.B.B run west
0 Screw Loose's Repairs
0 New England 2018
Last Post: joes95bobber
0 What's your helmet?
Last Post: r4fthrs
Last Post: spacecoast
Last Post: hhugger
Last Post: JensWest
Last Post: Vohnsen
Last Post: RKN
Old 16th July 2009
madfox22 madfox22 is offline
Sportster/Buell Model: XLS1000
Sportster/Buell Year: 1982
Other Motorcycle Model: BSA 650 chopper
Other Motorcycle Year: 1970
madfox22 is an unknown quantity at this point
Default XL shifter shaft
Am in the process of rebuilding another Ironhead motor. This is a 1979 model, which means left hand shift. By far not the 1st one I have done.
After ordering an assortment of shims and spacers for Jireh, I assemble the transmission on my work bench and get the proper spacing and clearance between the gears and the forks. I have no shifter shaft yet, but I can get my clearances and both of the shaft thrusts correct before I need the shifter shaft.
I installed and removed the transmission assembly several times before I was satisfied with the mainshaft and counter shaft thrust.
I had found a shifter shaft on Ebay for $17.00 I thought I was buying a used one, but was elated when a brand new one showed up.
I installed the shifter shaft into it's little hole in the right side case and lined the ball up so it would slip into the shifter pawl while I slide the transmission in place. The transmission went is just a short distance and stopped. Try as I may it would not go. I determined the shifter shaft was hitting the pawl housing, so I took a grinder and ground a flat spot on the shaft to clear.
Now the transmission goes all the way in, but I can't get it to smoothly run thru the gears. Removed it again, and found the arm that goes from the shifter rod to the pawl is hitting the top of the pawl. I put the pawl on the grinder and slightly round the housing so this arm will clear. Reassemble the transmission and shift thru the gears with no problem.
Before going any farther, I pickup up the primary cover to check and make sure it will go on. NOPE. The shifter shaft will not move back toward the rear of the engine to allow the bolt and dowel holes to line up. Still hitting the shifter pawl.
I am convinced this new shaft had been made in China or somewere and it is now in my junk bin and I am looking for another shaft.
Has anyone else run onto this problem ?
Old 1st October 2009
1982ironhead's Avatar
1982ironhead 1982ironhead is offline
Bike Builder
Sportster/Buell Model: xlh1000
Other Motorcycle Model: Triumph
Other Motorcycle Year: 196x
1982ironhead is on a distinguished road1982ironhead is on a distinguished road
not yet, but i do have to replace the rod your having trouble with, any brand recommendations for a new shifter rod that fits right? mine is an 82XLH
Old 2nd October 2009
Yruyur Yruyur is offline
Yruyur is an unknown quantity at this point
I was curious if the eBay ones would work as I was on there just this morning and noticed a bunch but they were new and billet I think.
I ended up buying a used on on Ebay, and it fit just fine, so I still don't know what the deal was with this one. It has to have a slight bend in it to clear the trans door and come out the primary. I was afraid this would throw the seal off center, so I ain't gonna use it on this project because this motor will be for sale soon and I want it to be right.
I'll use this shifter lever on one that I plan on riding for a while to make sure it will work alright.
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Asian junk parts strike again, it sounds like to me.
Not sure if Andrews or Jims makes these parts? They do most other gearbox parts and are worth paying the extra money for.
