0 Diagnostic help
Last Post: RKN
0 Head gaskets.
0 The country store
0 So Cal Ironhead Gathering
Last Post: leucadiaGuit
Last Post: cotton1
Last Post: mct496
0 headight housing
Last Post: The Doctor71
Last Post: cotton1
Last Post: cotton1
Last Post: cotton1
0 Hope Cove, 20th May 2018
Last Post: seajay
0 oil cooler or not?
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Pender1
Last Post: MatHormell
0 A Day in the Life...
Last Post: cotton1
Last Post: cotton1
Last Post: lugster
Last Post: lugster
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
Old 4th May 2007
StrokeII StrokeII is offline
Sportster/Buell Model: 883 XLCH
StrokeII has disabled reputation
Default Problems in First Gear
I'm not sure if my clutch is slipping in first or what. Usually happens when the engine is cold but has happened when hot as well. Starting out in first gear, it slips and catches momentarily a couple of times, especially if trying to accelerate into traffic. All I can do is get it into second and it is fine.
I've adjusted the primary chain, the final belt, and the clutch. I use the HD Sport-Trans fluid.Any ideas what else to try? It seems to be getting worse, but other than first, it runs great. Any help/suggestion is appreciated.
Andy
2002 883 Custom, 1st Harley
SE Slip-0ns, Chrome This, Chrome That. Still paying taxes.:tour
Old 4th May 2007
maddog's Avatar
maddog maddog is offline
Sportster/Buell Model: Hugger 883/1200
maddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura about
Did you adjust the clutch cable free-play ?
Night Train + Street Fighter= NIGHT FIGHTER
MY GALLERY
"It's just a Sportster, but I'm saving up for a Big Twin."
That's like saying...
"It's just a Corvette, but I'm saving up for a Station Wagon."
STEPHANIE FELD
HOT XL MAGAZINE
SUMMER '97
He was asked, "Why do you ride?" He considered the question carefully for a few moments. "The Lean", he replied.
Old 4th May 2007
myrl883's Avatar
myrl883 myrl883 is offline
Sportster/Buell Model: XLH883
Sportster/Buell Year: 1991
Sportster/Buell Model #2: XLH883 Hugger
Sportster/Buell Year #2: 1993
Other Motorcycle Model: Honda XR200R
Other Motorcycle Year: 1990
myrl883 will become famous soon enoughmyrl883 will become famous soon enoughmyrl883 will become famous soon enoughmyrl883 will become famous soon enoughmyrl883 will become famous soon enoughmyrl883 will become famous soon enough
I have the same problem on my '91. I started a thread on it a few months back, but so far no answers. Mine used to do it one time on the first clutch engagement when cold, but it's been happening with increasing frequency. It no longer has to be cold, either.
I don't know if yours is exactly the same as mine. Mine will engage fine, then slip (badly) momentarily while accelerating in first. It ONLY happens in first gear. Sound like yours?
I hope one of us identifies the problem! I don't want to go into it blindly, but I'm planning on disassembling my clutch for a full inspection.
My first question was what the "spring plate" does, but I've learned it's function and don't see how it could be the culprit. Next question - I've heard of a compensator - what is it, and what's it do?
Old 5th May 2007
chrishajer's Avatar
Sportster/Buell Year: 1988
For StrokeII - my guess is you will find worn dogs on the gears inside the transmission. Fairly common in the early 2000 years prior to 2004. If it were me, I would take a good look at everything inside the primary (chain, motor sprocket nut, disassemble the clutch) and if you find nothing there, go into the transmission. When you get inside the transmission, make triple sure you check everything and know what you're looking at. A seemingly minor amount of wear on the dogs will cause it to do exactly what you're describing. You might look at the gears and think there's nothing wrong with them. Post pics when you get it out, or have a knowledgeable mechanic look everything over really well.
It makes sense to look over everything external too, like the clutch cable and adjustment and belt and belt pulleys, to make sure there are no problems there before you go into the primary.
For myrl883 - it's not as common on the 90s 5-speeds, but it still happens. I would follow the same advice.
RE: the spring plate (judder plate) - when that thing goes, it usually makes the clutch drag and makes it hard to find neutral.
Good luck.
--Chris
Old 5th May 2007
davidcar's Avatar
davidcar davidcar is offline
davidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura about
You can do an easy test to see if it is engaging 100% For the next few rides when changing to 1st gear at the lights, push on the gear level quick and firmly then let the clutch out so that the bike jolts, let the clutch out twice jolting the bike before leaving the lights and see if you still have the problem.
1200 XLH, "D" shaped exhaust port, SE 497 cams, 9.5:1 CR, 1.850 inlet & 1.615 exhaust valve, 48 primary & 190 main jet, NOKK needle no shim. 84TQ & 81HP
Old 12th May 2007
Xldevil's Avatar
Xldevil Xldevil is offline
Sportster/Buell Model: 74",Buellized 5spd.engine
Sportster/Buell Year: 1986
Sportster/Buell Model #2: M2 88" engine
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Suzuki GT 550
Other Motorcycle Year: 1976
Xldevil has disabled reputation
I have had the same probs with my 2000 XL and my 2002 Cyclone tansmission.
I replaced 1st and 4th gears( whose dogs engage to each other) on both trannys by Andrews gears.Thanks to the trapdoor type( how could the moco stop that?) of transmission it has been an easy fix.
Never had that problem again.
Ralph
Old 12th May 2007
beuz's Avatar
beuz beuz is offline
Sportster/Buell Model: SPORTSTER "old boy"
Sportster/Buell Model #2: SPORTSTER CR (sold)
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Suzuki GSF 650 Bandit
beuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond repute
I had the same problem but only had to change the 1st gear sprocket on the secondary gear box tree. You have sometimes to replace the 3rd gear also...
On this pic, you can see where it's damaged :
Old 20th May 2007
franco1973
Guest
Posts: n/a
I have the same problem on my 92 sportster. Does the same thing in first gear,cold or warm.
Old 20th May 2007
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Try adjusting your clutch?!?! (Not the cable, the clutch itself)
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 6th July 2007
bwchoppers's Avatar
bwchoppers bwchoppers is offline
Sportster/Buell Model: EVO XL deluxe
Other Motorcycle Model: Shadow
bwchoppers has disabled reputation
This message was very usefull, in fact I found the damage in 1st and 3rd gears but the problem now is where I can buy obviusly with better quality and prices. I waith for help, kind regards.
