Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
Old 22nd July 2009
miahallen miahallen is offline
Sportster/Buell Model: XL883C
miahallen is on a distinguished roadmiahallen is on a distinguished roadmiahallen is on a distinguished roadmiahallen is on a distinguished roadmiahallen is on a distinguished road
Default intake/jets/exhaust upgrade - effect on gas milage?
I've got a bone stock '06 883C with a Kuryakyn Pro-R Hypercharger and hi-flow K&N on the way
I'd like to jet the carb, and add a SuperTrapp 2-1 exhaust system to improve performance a bit.
My question is, what is the tradeoff? Will my milage suffer? How much? Any other downsides that the upgrades will create?
Thanks!
Old 22nd July 2009
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
IMO:
You should suffer very little in MPG, Because if the engine is properly tuned it will become more effiecent.
The reality though is you may loose a small amount of MPG's Simply because with it running this much better you will likely Not drive easy...!
Old 22nd July 2009
What Matt said.
Old 22nd July 2009
FoxsterUK's Avatar
Not disagreeing with the other guys but it depends where your tuning is coming from and where you are going to. If you start with a stock bike running lean with an AFR of around 14.5-15.5 and add cams, ignition, A/C, pipes, etc and tune the carb then you will definately see the difference in MPG. You can go from 150 miles to reserve on a 4.5G tank to about 110 miles.
Fox
I had an '05 1200R.
Old 22nd July 2009
You are correct. It all depends of the tune of the AFR.
Old 22nd July 2009
AFR = air/fuel ratio right??? (sorry, I'm a total rookie)
Do I need to find a Harley mechanic to adjust that? I live in northern Japan, and I don't know of an authorized factory mechanic anywhere north of Tokyo.
Old 22nd July 2009
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Yep.
There are a lot of options for DIY tuning. There are also a few self tuning devices (black boxes) available.
