0 Tool Roll Help
Last Post: RökkenRöll
Last Post: blindfredy
0 S.Fla. shop
Last Post: the cowboy way
Last Post: Moon Wolf
0 Back in Sporty Land
Last Post: skien
0 WTF Happened
Last Post: jordan1200
0 Brake light stays on
Last Post: 1980SPORTSTER
Last Post: The Crusher
0 The country store
Last Post: lugster
Last Post: Xl-1250r
Last Post: jcro61
Last Post: Titaniumrust
Last Post: screndname
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 79 ironhead
0 2016 48 Hesitating
Last Post: 201648Rider
0 If you have European tilt
Last Post: Serious Blac
Last Post: BrokenIron
Old 23rd July 2009
boogop boogop is offline
Other Motorcycle Model: V-Star 1100
boogop is an unknown quantity at this point
Question 01 EVO jumping out of gear?
It's happened twice now, both time I was going down an on-ramp to the freeway and torquing it hard. Twice it's jumped out of third gear, but only when I'm really accelerating hard.
I haven't had a vehicle do this since my 1958 Chevy Apache pickup with three on the tree. Am I concerned?
Old 19th September 2009
Sporty77's Avatar
Sporty77 Sporty77 is offline
Sporty77 is on a distinguished roadSporty77 is on a distinguished roadSporty77 is on a distinguished road
Worn shifter forks. You could chip gears in the tranny. This problem will continue to get worse if not corrected.
xlint89's Avatar
xlint89 xlint89 is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 89
xlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura about
It's not normal. Something will need to be addressed.
I suggest sending the trans to R&D Motorsports in Clearwater FLA. They do nice work and will show you everything that needs to be replaced, no more....
Stock............. Isn't that a soup or something?
Old 28th September 2009
Ratso-rizzo Ratso-rizzo is offline
Sportster/Buell Year: 01
Ratso-rizzo is an unknown quantity at this point
there was also an issue with the shift drum on that year and a year or two before and after. the pins in the shift drum that the detent rides on that also help it hold in gear some what come loose and then when you shift into gear it does not engage all thee way ahd jumps out of gear and that can cause more damage like bending a shift fork and wearing out the dogs on the gears.R&D is a good choice they do good work and will back-cut your gears so they engage smoother and hold better
