Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Lighting
0 900 heads contd..
Last Post: Keithybloodygeorge
0 Oil Tank question
Last Post: jordan1200
0 1967 XLCH stroker project
0 Fact or Fiction - HP Claims
0 NewProject
Last Post: Rodzilla
Last Post: vagrant318
0 Cylinder Piston kits
0 Thinking about buying a Ironhead
Last Post: ericfreeman
5 Pre-Oil the motor somehow after long Non-running?
0 Trouble Code B1611?
Last Post: Jcolleyoh
5 Wasted spark ?
Last Post: Magneto Sportster
0 surges and/or hunting on 1200 EFI's
Last Post: whittlebeast
Last Post: kaveebee
0 More of a reintroduction
Last Post: k9unitb
0 Iree's jukbox joint
0 Battery life with total loss ignition
Last Post: Diogenes415
Last Post: lugster
0 Viking bags??
Last Post: gravydog
0 the far west burbs of Chicago
0 Diagnostic help
Last Post: BradX13
Old 6th May 2007
MTime's Avatar
MTime MTime is offline
MTime has disabled reputation
Unhappy Right Rear Turn Signal Problem
Ideas - Right rear turn signal stopped working on my '01 1200 Custom. I have
-Replaced bulb
-Checked harness
-Checked Fuse
If I swap the L/R plugs in the tailight module, the right rear turn light WILL work when I press the left turn signal button. So I'm thinking it is something other that wiring or fuse.
Help????
Old 6th May 2007
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
Have anything extra in the ckt. such as a module to convert the turn signals to running lights?
If so, take it out and see if it changes things.
I had a add-on Kuryakyn Turn Signal controler on my bike, wires got shorted then the harness fell against the tire. Repaired the wiring but I couldn't get the light to work, even though I had 12V battery and ground. I did the same thing, swapped the leads as you did and tbl stayed the same.
Funny, my problem was with the same rightside bulb.
It would not light a stock bulb but it would light a LED bulb. Had me scratching my head.
Then I remembered I had the module in the ckt. Took it out and lights started working. Smelled the module and it smelled like it was fried. Peeled back the insulation over the ckt. board and I could see where it got fried. Had to replace the board. Evidently the stock light was too much of a load to light but could still handle the LED bulb after the ckt. board got fried.
All you need is 12V battery and grd. to make the lights work. Make sure you have both.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
Old 6th May 2007
MTime's Avatar
I also [had] turn signal controller, but I removed this [forgot to mention]. Still scratch'n my head
Old 6th May 2007
decman decman is online now
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Look at the wiring under the fender. If it comes loose and rubs
on the tire it will wear down real quick.
dec
Old 6th May 2007
MTime's Avatar
Yes - I've gone through the fender wiring completely. Under the seat there is a module that a deutsch connector goes into b/4 going to the back lights. Is that a possibility?
Old 6th May 2007
gusotto's Avatar
dec
Yes, check it out with a good light and get the dirt off the wiring so you can see it well.
That was my original problem when the harness slipped out of the loom, hit the tire and wore through. Turn the wiring harness enough to see all sides. It doesn't take much of a rub to open the wiring.
Old 6th May 2007
gusotto's Avatar
It does come out of that connector but wouldn't think you'd have problems there. They seal them very well.
Checking my factory electrical manual, it comes down to possible open wires or defective turn signal module (TSM).
The book gives an involved tblshooting sequence.
Do you have 12V and grd at the rear light?
Also, you can swap a buddies turn signal module and see if the tbl clears? Both Sportsters and Dynas use the same TSM.
Old 6th May 2007
jwb's Avatar
jwb jwb is offline
Sportster/Buell Model: XLH883 standard
jwb is on a distinguished roadjwb is on a distinguished roadjwb is on a distinguished roadjwb is on a distinguished road
That means the right rear circuitry including the TSM is ok.
Did you check to see if the right TS switch operates the left TS lamp?
Maybe the problem is in the switch?
2002 XLH883 Standard, V&H straight shots/dynojet/K&N hi-flo, Tach Kit,
Full front fender, premium leather saddlebags, detachable compact windshield and some chrome.
Old 7th May 2007
MTime's Avatar
I will check the TS Module and the wiring again.
jwb - tried alternating the ts switch.....not the switch
