0 1974 Ironhead
0 24633-77 Breather assembly
0 Ei
Last Post: Serious Blac
0 New from Utah
0 Post season carnage
0 De-lowing a Superlow with Progressive Monotubes?
Last Post: FuriousGeorg
0 Exhaust Clamp Fitting
Last Post: Yochstein
Last Post: norseXL
0 Rubber mount Oil tank Vent line Routing
0 Need help on bolt size - 92 XL1200, mid pegs
Last Post: r4fthrs
0 Reflectors...Yeah, or Neh
Last Post: 60weight
0 1250 Conversion troubles
Old 14th April 2005
bamf_shadow's Avatar
bamf_shadow bamf_shadow is offline
Sportster/Buell Year: 1976
bamf_shadow is an unknown quantity at this point
Default how to remove clutch hub nut?
76 sporty. I broke the damned kicker shaft, so I have to pull the clutch hub to get to it. My problem is that I can't get the dang clutch hub nut loose. It is a 1.5" nut, but I can't torque on it enough without the rear wheel spining. I thought about putting a wrench on the drive sprocket nut to compinsate, but allas my arms are too short to hold one side and pull the other.
My Clymer says to use a special tool called the grabber, kinda like a vise grip. Can't find one in any local tool store (very limited selection here). I tried some 90* needle nose pliers, but that didn't work either. Any suggestions?
Old 14th April 2005
Gone Gone is offline
Motion Pro makes a clutch holding tool. I think it is what you are describing. It's what I used for clutch hubs and countershaft pulleys.
http://www.motionpro.com/Docs/servicetools_3.html
The tool is also sold through JC Whitney. The SKU number is: ZX063598U It's $27.99.
Chuck
Old 14th April 2005
yeah that is the funky tool. What is the backyard mechanic way of doing it? I know that there has to be some way. Also, my first approach of holding the drive sprocket nut failed, it just loosened the drive sprocket nut...
HELP!!!??!!?!?!
Old 14th April 2005
Impact wrench...?
Old 14th April 2005
don't have an impact...
Looked into the tool, seems to fit the bill. I just can't see buying a $30+ tool just for this....
Old 14th April 2005
dwardy dwardy is offline
Sportster/Buell Model: '92 883/1200
dwardy is on a distinguished roaddwardy is on a distinguished roaddwardy is on a distinguished roaddwardy is on a distinguished road
I used a 2 x 4. Just a hunk small enough to fit in between the runs of primary chain and wedge in there.
Old 14th April 2005
dwardy, you are thinking of the front sprocket. I am talking about the nut inside the clutch hub itself.
Old 14th April 2005
pilot pilot is offline
Sportster/Buell Model: Buell Chopper
Sportster/Buell Model #2: Sportster Custom
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Various others
pilot is an unknown quantity at this point
Just did this on my evo sporty...
Have a friend hold the rear brake tight, then use a breaker bar and socket, install the same way, worked for me...
Thats my backyard approach, good luck.
Old 14th April 2005
Oh???
Oh!!!
Old 15th April 2005
pilot, I tried your idea, but it didn't work for me. I have mechanical rear brakes, and even though the shoes and drum are new, They still won't hold back that kind of force. I am about to give up here. I have to get this damn thing off to get to the kick shaft.... Any more ideas???
Similar Threads
04-05 Cam Install How-To (complete with pics) Turbota Sportster Motorcycle - Bottom End 31 25th April 2013 22:53
74 clutch problems raymeg Ironhead Sportster Motorcycle Talk (1957-1985) 111 1st August 2005 11:28
Clutch drag jag1 Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 1 14th February 2005 19:11
Clutch advice needed. BonRu Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 10 11th February 2005 14:39
Changing Cam NYSPORTY Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 11 15th January 2005 15:41
