Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
Old 28th July 2009
Rich361 Rich361 is offline
Other Motorcycle Model: Honda CB400f
Other Motorcycle Year: 1975
Rich361 is an unknown quantity at this point
Default Tapping Noise from top end after 883 to 1200 conversion.
I have just completed a 883 to 1200 conversion on my 2003 Sportster... I got my existing jugs bored out, put some SE pistions in and got the head done...
Once I started it up a tapping noise is coming from the top end somewhere... possibly the lifters?? The noise starts and stops while idleling and stops where riding?? Any ideas??
Old 28th July 2009
CharlieB's Avatar
CharlieB CharlieB is offline
Sportster/Buell Model #2: XLH 883 Deluxe - sold now
Sportster/Buell Year #2: 1986
Other Motorcycle Model: FXDWGi
CharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really nice
lifter noise is common after a top end tear down, but should go away after a few minutes
Old 28th July 2009
Thanks for the reply.... I've done about 1000km on it and the noise is still there??
Old 28th July 2009
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
Welcome to the forum!
Did you notice anything before the conversion?
Old 28th July 2009
Thanks for the welcome... There was no noise before the tear down, I took it for a full serivce and check before the tear down so I new the bike was running fine...
Old 28th July 2009
Old_Goat57's Avatar
Old_Goat57 Old_Goat57 is offline
Sportster/Buell Model: XL883/1200 Custom
Old_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the roughOld_Goat57 is a jewel in the rough
I noticed a consistent top end noise after my conversion, but my mechanic explained it as consistent with the radical cam (Woods Knight Prowler .590 lift, long duration) and heavy duty valve springs.
Essentially, he said the more squared profile of the cams were causing the extra top end noise as the valves were closing with more force than with the stock valves & springs.
It makes sense to me and the engine performance is there, so I stopped worrying about it - it's been 6,000+ miles since the conversion with no problems.
Did you change your cams or valve springs?
"Old Goat" (Dave)
The nick has nothing to do with my age or farm animals...
Old 28th July 2009
Hi, My funds ran out when it came to Cams, I put bigger valves and springs in and re-ported the heads...
The tapping isn't constant, it comes and goes... can happen when its cold, can happen when its hot?? The guy who helped me do the job suggested it's a lazy lifter?? Not really sure how a lifter can become lazy?? haha
I'm happy to ignore the noise but am worried I may cause damage to the engine??
Old 29th July 2009
CharlieB's Avatar
Nada. Number one culprit is lifter noise. The stock lifters are very good, but not above failing on occasion. Getting the rockers mixed up from their original locations will alter the wear pattern placements.
Depending on what was used... you might need adjustable rods.
Sorta goin on what "could" cause noise and not destroy things in the miles you drove. Something like a valve whacking the piston would have caused a catastrophic failure by now.
I suppose a bad fitment of piston pin would cause noise and not immediately destroy things. Ditto bad fitment of rocker shaft.
And what everyone else said too
Old 29th July 2009
ReddTigger's Avatar
The stock 883 piston is oval shaped and as it heats up becomes completely round. while the Aftermarket 1200 conversion type pistons are usually forged and are completely round from the start. TYpically most shops allow for the expansion of the forged product by giving a greater tolerance. This could be contributing to your noise.. it may sound like its coming from the top of the motor, but in reality is not..
one way to test is to re-install the stock mufflers and listen again to your motor. you'll be surprised what you can hear when the exhaust is quieted down.
States I've Ridden in
71.3 hp 70.8 tq
Old 29th July 2009
Motorhead52's Avatar
Motorhead52 Motorhead52 is offline
Sportster/Buell Model: 883 sportster
Other Motorcycle Model: BMW
Other Motorcycle Year: 1973
Motorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura about
With mine with the wiseco kit has some piston slap when warm
