Last Post: jammantoo
Last Post: lugster
0 Viking bags??
Last Post: cotton1
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 2001 883 'customizing' log
Last Post: cotton1
0 rpm jump pulling in clutch
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: jordan1200
Last Post: Racepres
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
0 Value of a Boattail?
Last Post: gravydog
5 Am I looking for Trouble ?
Old 14th April 2005
go-n-postl's Avatar
go-n-postl go-n-postl is offline
Sportster/Buell Model: xlh 883 hugger
Sportster/Buell Year: 96
go-n-postl is an unknown quantity at this point
Default speedometer sensor removal
Im trying to remove my speedometer sensor as it is defective/dirty. How do you remove the screw holding it in?? The maintanence manual makes it sound as if you just reach in and put the allen tool in the bolt but i cant get to it. What is the most field expiedient way to remove with out dismantling the bike? Is there a special tool that I can buy that will make this process easier?? Thanks in advance!! ---- tim f
Old 15th April 2005
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
I used an allen bit, but turned it with the closed end of a 1/4" wrench.
Ed
Ed
The Only Y2K dual-set 883C
So Cal
Old 15th April 2005
I had to remove a bunch of parts: rear exhaust, sprocket cover, etc. It is still hard to get at because of the angle.
Old 17th April 2005
go-n-postl's Avatar
Thanks for the responses. I got her fixed.only had to remove pipes. Had to wait a couple days to get part in so why it was apart I cleaned everything. i also wash/polished everthing under pipes that is hard to get to when pipes are on. I used some of the MoCo brand "xtreme" metal polish on some of my stubborn spots. I think that that works great or at least way better than the polish Ive been using. It is a cotton wadding (kinda like brasso) with some kinda of pink liquid saturated into it. anyhow thanks again -- timf
Similar Threads
Where to relocate speedometer danii Sportster Motorcycle Custom Finishing 62 25th December 2007 12:41
Speedometer Quit Gone Sportster Motorcycle Motor - Top End 9 11th September 2005 21:28
HD Tech Tip - 2001-2003 - 1200 Speedometer Part # bplinson Sportster Motorcycle Electrical and Ignition 0 19th February 2005 07:29
Ironhead Mick's Project, Speedometer Drive IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 2 14th January 2005 05:26
Fogged Speedometer yubman Sportster Motorcycle General Discussion and Problems 6 29th December 2004 10:24
