Last Post: Screw Loose Dan
0 Primary Oil INSANITY!
0 Lowboy frame conversion
0 What jets do you use?
Last Post: David L.
0 FNG from OKC
Last Post: David L.
0 Show your tank decals
Last Post: Tonail
0 Solar battery charging
Last Post: Ranchero50
Last Post: Naplesron
Last Post: Grumpy-Biker
Old 4th August 2009
Dogstar's Avatar
Dogstar Dogstar is offline
Sportster/Buell Model: XL883L in Pewter Pearl
Dogstar will become famous soon enoughDogstar will become famous soon enoughDogstar will become famous soon enoughDogstar will become famous soon enoughDogstar will become famous soon enoughDogstar will become famous soon enoughDogstar will become famous soon enough
Question Cylinder head exhaust port nut: torque value difference
There appears to be a difference in the recommended torque value for the cylinder head exhaust port nut:
  • 2008 HD Sportster Service Manual (FSM; #99484-08A) = 96-120 in-lbs
  • HD Screamin' Eagle Street Performance slip-on muffler kits (#80502-07 & #80503-07) = 60-80 in-lbs
Hmmm, that's odd. With so many folks here installing the SE SP's I'm surprised this has not been pointed out ... or I missed it.
What gives with the difference in the exhaust port nut torque values?
  • Is it because the SE SP installation instruction sheet is outdated (J03971; rev 2007-10-08)?
  • Does the SE SP instruction sheet assume that a SE SP exhaust gasket kit (#17048-98) will be used, which requires the lesser torque?
  • A change between the 2007 & 2008+ Sportsters?
  • A typo in the FSM or SE SP instruction sheet?
Which cylinder head exhaust port nut torque value should we be using (ie. 96-120 in-lbs or 60-80 in-lbs), with the stock gaskets &/or SE SP gaskets?
I'm so confused ...
Thank you. Dogstar.
Home of the 2010 Winter Olympics. Enjoy it for me 'cuz I'll be too busy working!
"Canadian by birth. Rebel by choice." --- Dogstar, 2009. Stock performance plus shiny stuff ... to be continued.
Old 5th August 2009
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
Very interesting! I've found several typos in my service manual. Possibly a typo? I thought 'gaskets' at first, but
Old 5th August 2009
TechRep's Avatar
TechRep TechRep is offline
TechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of light
It has been awhile, but I don't remember my slip-on's requiring the exhaust pipes to get torqued. Only removing and installing the mufflers. Am I missing something?
But as a reference, my 04 manual also has the exhaust port nuts as 96-120 in-lbs.
Old 5th August 2009
Dogstar's Avatar
Removing the pipes to facilitate the muffler re-n-re's is the recommended approach per the FSM & slip-on installation instruction sheet, however it's debatable whether it's actually required (see "How hard is it to install slipons?" thread). Some, like yourself, choose to just manipulate the mufflers enough over the interconnect brackets without loosening the cylinder head exhaust port nuts.
I chose to replace the stock exhaust port gaskets with the SE ones so I had to take the pipes off anyway. All's well except for the confusion over which torque value to use now ... I used the commonly-accepted 96 in-lbs just to be on the safe side.
