Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
27421-99a, carb, fuel system
Old 5th August 2009
truckmen's Avatar
truckmen truckmen is offline
Sportster/Buell Model: Sportster 1000 cc XLH
Sportster/Buell Year: 1979
truckmen is an unknown quantity at this point
Default '79 1000cc carb part # 27421-99A
Hello All!
Harley Davidson carburetor part #27421-99A
Has anyone had experience with rebuilding one of these carburetors?
This is on a '79 1000cc XLH Sportster with 22,000 miles.
While I am on the subject:
Has anyone considered or actually done an upgrade of the fuel system, like going to some sort of fuel injection or better quality carb?
Are there any mods which can be done to this carb?
Sincerely,
Ralph M Bohm
truckmen@yahoo.com
Old 5th August 2009
No mods really necessary. The CV carb can support a 100hp motor in stock form. Some of the Evo riders may have more experience with rebuilding than the IH guys. Can't swing a dead cat for hitting a CV in the Evo group... they're far less common over here.
Jets and possibly a different needle to cure transition flat spots are all that you'll probably ever need. Then there's the Dynojet kits - opinions vary on whether to do that "upgrade".
Old 6th August 2009
truckmen's Avatar
Thank you GA Ironhead for the info.
Old 6th August 2009
+1
Ixnay the DynoJet kit no thunder slide or thunder jet needed either.
Start with a 46 - 48 pilot and a 170 main put 2 very small washers under the needle if you need it.
If the carb has been modded, get another.... they are cheap, you can buy them by the box full at the swap meets.
Old 7th August 2009
Stone stock is the preferred mixer. The idle mixture screw is easily hosed, if one isn't careful. If you're shopping, look for a carb with the IMS cap still in place.
