Last Post: Yellowstone Kelly
Last Post: Diogenes415
Last Post: lugster
0 Feeling in trouble.
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
Last Post: Jollly Rogers
Old 12th August 2009
DC in PHX DC in PHX is offline
Senior Master Bike Builder
DC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really nice
Default At My Wits End...Wild Random Instability Continues
Hi Guys,
I hate to say it, but I may have to have the dealer pick up my Sporty and have a professional diagnosis and repair.
Last week I described my problem here:http://www.xlforum.net/vbportal/foru...d.php?t=574105
When I pulled the rear wheel off, the retaining ring for the caliper piston boot fell out http://www.xlforum.net/vbportal/foru...d.php?t=574878
After taking the rear wheel off, one bearing seemed a tiny bit stiff, so I had new bearings pressed in (80K on those bearings). So I have new bearings and seals on the back wheel.
Since the retaining ring is not sold seperately, I had to buy the caliper rebuild kit. So, I rebuilt the caliper since I had to buy the parts anyway. The rear pads had a lot of meat left on them, so I did not change those. I made sure to scotch-brite the rotor too.
I reassembled everything very carefully, made sure the rear alignment is right, belt tension within spec, everything torqued right, etc.
Put it all back together. Rode it around the neighborhood at low speed for a half an hour or so. Everything was fine. Took it out on the road to 50 MPH, everything still fine. Took my hands off the bars at 50, the bike was nice and stable, pulled just a tiny bit to the left though. Did a few "panic" stops, everything seemes fine.
So I figue, all is good.
Took the bike out again, and then the bike got all out of contol again right after I made a left turn and accelerated to 40MPH. I almost had a head-on with a car! I had to muscle the handlebars at 10 MPH just to keep in some sort of control. Luckily I was able to take side streets home. It feels just like a flat tire, that is the best I can describe.
Rant over
I guess, for the first time since I joined this forum, I will have to have the dealer look at my Sporty
Ideas???
Thanks!
DC
linkin5's Avatar
linkin5 linkin5 is offline
Other Motorcycle Model: Honda XL 125
Other Motorcycle Year: 1982
linkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nice
Maybe just maybe the problem is in the front and not the rear, I don't have a clue but keep an open mind about it.
K3vl4r's Avatar
K3vl4r K3vl4r is offline
Other Motorcycle Model: Yamaha XS 750 E
Other Motorcycle Year: 1978
K3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really niceK3vl4r is just really nice
Are the adjusters for the rear wheel set properly? if one is forward of the other (in this case, making the rear wheel point to the right-forwards) it would shove your bike to the left...i was only assume the problem is in the back because you didnt touch the front...double check? are the bearings pressed in straight?
Good point, it could be my perception is wrong.
DC
I am pretty sure the adjusters are right, at least by using the method described in the manual for alignment. There could be a slight incorrect adjustment due to using the home-made alignment tool.
As far as the bearings being pressed in right, I really don't know. When I put it back together, I did not notice anything wrong (like a spacer being crooked on the axle).
Thanks
DC
K3vl4r's Avatar
Do you have a set of calipers to measure the distances on each side? or at least a ruler to see if they are close? if they are really close by ruler, i cant image it would pull that hard to one side...
When you did the 1st test ride, were you ginger and nice to it, or did you go WOT a few times? Did you do a WOT on the second run after the left turn and thats when it went wonky? If the adjust was loose or came loose, possibly the WOT yanked on an adjuster?
just tossing stuff out....
Yup, I was nice and easy on it, till it went wild. I did not go WOT, but I did open it up some...
Gonna check alignment again and post results.
Feel free to keep tossing!!
TNX
DC
[QUOTE=K3vl4r;2103469]Do you have a set of calipers to measure the distances on each side? or at least a ruler to see if they are close? if they are really close by ruler, i cant image it would pull that hard to one side...
Well, using a steel ruler, they are within 2 mm of each other...
I am beginning to think front end...
Thnaks
DC
bdbecker's Avatar
bdbecker bdbecker is offline
Sportster/Buell Model: 883 XL
bdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of light
If your axle was adjusted improperly (crooked), you should be hearing a weird noise from the belt trying to walk its way off the pulley. Don't get too carried away with the calipers either, as K3vl4r hinted at, if you're dead on using a ruler, it shouldn't be pulling like that.
What I'm starting to wonder is if the problem might be with your swingarm pivot (where it attaches to the frame). If something got bent/tweaked/broken in that area, it could be causing some of you problems.
Dragstrip King of the Popes of Hell MC
Weo's Avatar
Weo Weo is offline
Sportster/Buell Model: 883-1250
Other Motorcycle Model: 600cc CBR
Other Motorcycle Year: 1987
Weo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to all
I was just going to say that when my front forks were problematic, I originally thought it was my back tire slipping. For me, it was a busted fork seal with most of the oil gone.
"Insert witty comment here" -1999 883-1250 XL, N4 cams, NRHS AC, ST 2-1, Golan petcock, Ricor Intiminators, aesthetic changes
