0 Value of a Boattail?
0 z bars
Last Post: lucifer_mr2
Last Post: big andy
0 Brake Squeek
Last Post: Tucsonmax1
0 Won't rev past 1200
Last Post: Jowniofownio
0 Not charging issue!
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Mikuni HSR42
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Old 16th August 2009
eomer's Avatar
eomer eomer is offline
eomer is an unknown quantity at this point
Default Gas tank
Im thinking about eventually switching out my stock tank. how much of a bitch would it be to retro-fit, lets say a Street Bob tank?
Ride now!... Ride now!... Ride! Ride to ruin and the world's ending! Death! Death! DEATH! Forth, Eorlingas!
Jimbos883's Avatar
Jimbos883 Jimbos883 is offline
Sportster/Buell Model: 883/1212 XL Custom
Sportster/Buell Model #2: XLCH STROKER
Sportster/Buell Year #2: 1959
Jimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to behold
Check this out, everything you need to know and with excellant results.
http://xlforum.net/forums/s...d.php?t=570113
2004 Vivid Black 883 Custom, CONVERTED With NRHS 1212 Cylinders, 10.5 to 1 NRHS Dome Pistons, Stage 2 NRHS 1200 XB Heads, SE .551 Cams, TC88A, All the Right Stuff
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
It's not all that difficult unless your talking about having the guages and ignition switch in conjunction with the tank. The costliest part is the painting of the tank.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
eomer's Avatar
thanks jimbo, thats perfect!
eomer's Avatar
i do like the tank mounted speedo of the street bob though
Jimbos883's Avatar
Super Glide and Street Bob are both in the Dyna family so that write up will work for the the Street Bob. I'm assuming that the mounting of the tanks to the frames would be the same. So there you have it you can have your tank mounted speedo.
Now all you need are the parts and you are good to go. Good luck and post pictures as you are doing it.
Old 21st August 2009
eomer's Avatar
Will the fuel pump connectors match-up or will i have to run a carb?
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
The Street Bob is fuel injection. You could go to a carb, but it would be easier just to get another Sportster.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
eomer's Avatar
I meant to say, will the dynas male fuel pump harness connector match up the the sportsters female connector? i had just gotten back from a run after on top of working a 12 hour day. i may have simplified the question too much in my daze. sorry for the confusion.
