Last Post: gpydeski
0 hi from anchorage AK
Last Post: Veeflys
0 Runs rough on highway.
0 The Multi-tool thread
0 Spectro STL 75W140
0 S.Y.B. Next to a waterfall.....
Last Post: Bama Lee XLC
0 WTF Happened
Last Post: 83XLX
0 Sportster in custom softail frame
0 Project Strociek
0 Mainshaft bearing
Last Post: Four Speed
Last Post: Smerch
0 2 into 1 exhaust build
0 900 dual carb front head
0 Floppy kickstand spring issue, 1991 model
5 Summer time heat
Last Post: ccmman
0 What is the best '70's Ironhead to restore
Last Post: Whitewalls
5 Why Are You Still Married?
Last Post: Flowerpunk
Old 17th August 2009
cajun1957a cajun1957a is offline
cajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of light
Default Ok where is the oil?
I recently changed the oil in my 65 xlh. For some reason, I did not put any in the primary side. I have read in the manual that it shares the same oil as the crank case. (A common sump). I guess I assumed that it would use the oil in that. Went for a nice 30 mile ride and its noisey as all get out. I guess there wasnt a whole lot of oil in the primary side. Doesnt seem to have damaged anything but Im going to pull it down anyway.
Does a 1965 XLH use the same oil and does it get it from the common motor oil in the engine, or do I have to add it to the primary side as well? Some guys are using a heavy HD Primary oil. Should I be using that and if so, will it mix with the engine oil and cause some sort of damage?
randy
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Ouch...
72Iron's Avatar
72Iron 72Iron is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: Harley-Davidson
Other Motorcycle Model: FLHTCU (Geezer Glide)
72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice
randy
Answer: Two separate systems. 3QTS in the tank for the crankcase, and 24oz or 1.5 pints for the primary.
Hint: Get a FSM or equivalent.
Good reading: http://xlforum.net/forums/s...88#post1959688
I would do a total tear down on the primary side, and check the friction plates very well.
I gave up smoking, drinking and sex.
It was the worst fifteen minutes of my life.
RIP: Eli
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
Never Assume, You can use the same Oil but must fill the Primary side as per the proper capacity.. I use 60W on motor and trans.. Get a Service Manual........
The primary and crankcase may be separated. There is a factory transfer valve between the two that may have been sealed off, a thousand different ways. Or not. A lot can happen in 45 years...
The only way to know is to go in and look. Never assume the primary is oiled by the engine. The transfer valve allows the oils to mix, but the design is not intended to purposely lubricate the primary. A lot of people will separate the two, so that engine oil and primary oil don't mix. If that is the case, separate oils can be used in the engine and transmission.
GA thanks. I do know the transfer valve is still there. Ive always wondered why anyone would put a primary lube in the primary side if the transfer valve allows them to mix. Would that not destroy the engine oil if that happened. The book says that the oils are the same yet others use engine oil in the block and primary lube in the primary.. Whts your take on this
randy
jagdprcp's Avatar
jagdprcp jagdprcp is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1979
jagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enough
If the transfer valve is still in place, use the same oil in the motor and primary. If the transfer valve is plugged, use what ever makes you feel good. Either way change the oil regularly for best results.
Skeeeter
'76 XLH - 4 5/8" Stroker, Andrews V-9 cams, S&S Super 'E' and Barnett Billet Scorpion Clutch plus some cosmetic stuff
'79 XLH - Mostly stock except for cosmetics (for now!)
Shadowdog500's Avatar
Shadowdog500 Shadowdog500 is offline
Sportster/Buell Model: XLH-1000
Other Motorcycle Model: Honda Spree
Other Motorcycle Year: 1987
Shadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura about
The transfer valve is more of a breather than a oil transfer port. It is not meant to transfer oil from the crank to the primary. If allot of oil does transferrs through the valve from the crank to your primary it is broken and needs to be replaced or plugged as some do here.
I hope you didnt get too much damage.
Chris
Chris
It’s not really your bike unless you work on it yourself!
"Believe nothing, no matter where you read it, or who said it,
no matter if I have said it, unless it agrees with your own
reason and your own common sense."
-Buddha (536 B.C.-483 B.C.)
madfox22 madfox22 is offline
Sportster/Buell Model: XLS1000
Sportster/Buell Year: 1982
Other Motorcycle Model: BSA 650 chopper
Other Motorcycle Year: 1970
madfox22 is an unknown quantity at this point
The oil transfer valve allows oil from the crankcase to enter the primary side only if you have excess oil, or pressure in the crankcase.
Excess crankcase pressure from worn rings, or valve guides. Excess oil from the oil pump check valve seeping, or from other wet sumping problems.
If you plug the oil transfer valve, and still have the excess oil, or the excess crankcase pressure problem, then the oil will end up going out the breather pipe instead of going into the primary.
My brother always had to add to his oil tank, but drain about the same amount from the primary.
It seems that "oil transfer valve" is incorrect terminology. Can someone look this up in a parts book and post the actual correct name and part number please.
