0 first harley- help!!
Last Post: rickthrash99
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
Old 17th August 2009
FourCams's Avatar
FourCams FourCams is offline
Sportster/Buell Year: 1969
Sportster/Buell Year #2: 1972
Other Motorcycle Model: FXSTC
Other Motorcycle Year: 1996
FourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really nice
Default Oil Transfer Valve
EDIT: See post #40 for DR DICK's take on this topic.
I've heard a lot of stuff about the mysterious oil transfer valve but couldn't find a thread that's dedicated specifically to it - so I'm starting one.
The transfer valve should be threaded into the case behind the primary cover and to the rear of the front primary chain (drive) sprocked.
It looks like this:
The oil transfer valve was used from 1957 - 1976. (OEM part number 25075-55.) It was discontinued in 1977.
I've been under the impression that it was put there to help keep the dry clutches from getting wet and it's designed so that oil will go from the primary to the engine if the primary oil level is too high. Does this sound right?
If the oil transfer valve is not blocked, oil from the primary can mix with oil in the engine. Some people plug the oil transfer valve and use ATF or other primary lubes in the primary/transmission. I'd be interested in seeing the different methods people have used to block off the oil transfer valve and what primary lube has been used after it's blocked. (Please don't turn this thread into an oil argument.)
If I understand correctly, the trans needs to be vented seperately if the oil transfer valve is blocked?
Anyhow, here it is.. the oil transfer valve thread.
Please share your oil transfer valve wisdom here.
♠ 1969 XLCH ♠ 1972 XLCH ♠ 1996 FXSTC ♠
Sportster/Buell Year: 1972
Blocked mine off ('72CH) years ago. No ill effects seen. Pulled it out and a friend put a spot of weld in it. Its just as effective to pull the guts out and tap the hole and locktite a screw in. I did it because my primary was mysteriously filling with oil. Turned out to be a failed sprocket shaft seal. My motor sprocket was cracked thru the land that the seal rode on and that cut up the seal face. My trans vents thru a very small hole in the primary fill/inspection plug. And yes the trans needs to be vented somehow. I use 20/50 motorcycle synthetic as lube.
Ivan RoachCoach's Avatar
Banned
Default The El Cheapo way of doing it: Tap the hole in the valve...
...to either 8-32 or 10-32 thread-size (I forget which), thread in the appropriate screw slathered in red Loctite, and peen the screw head until it's distorted.
It'll never unscrew or back out of there --- EVER.
superwarden's Avatar
superwarden superwarden is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLC
Other Motorcycle Model: FXSTD
superwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of light
Yep get rid of it if you like. Not much oil is ever "transferred" through it.
Any date that is not on your tombstone is considered a lucky day.
RRB RRB is offline
Sportster/Buell Year: 1966
RRB is on a distinguished roadRRB is on a distinguished roadRRB is on a distinguished roadRRB is on a distinguished roadRRB is on a distinguished road
Doesn't sound right to me. I don't think it had anything to do with the clutch, as the plates were isolated behind the derby cover and "should" be impervious to the oil in the primary/trans. I don't think the intention of the valve was to keep the primary oil at a certain volume. I think the valve had more to do with crankcase pressure than with oil levels.
The problem is usually not oil from the primary migrating from the primary to the crankcase, but the other way around, at least in my experience.
Your thread is a good idea, though. I'm interested in what others have to say, too.
MDT's Avatar
MDT MDT is offline
Sportster/Buell Year: 61
Other Motorcycle Model: Superglide
Other Motorcycle Year: 74
MDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond repute
I just posted on another thread, it's a crankcase "breather". If oil splashes over to the primary side it is incidental. If you use the same oil in your tranny and your engine, it's not a problem. If you don't you should probably plug it. I don't plug mine.
When you sit on something, you built from parts;
You're sitting on top of the world.
FourCams's Avatar
So... what exactly is the purpose of the oil transfer valve?
The primary vents through the oil filler plug doesn't it?
I'm reasonably certain (but not positive) that if the primary is overfilled the oil will go into the engine throught the transfer valve. I don't think it's supposed to allow oil from the engine into the primary though.
MDT's Avatar
MDT MDT is offline
The pupose is to vent the pressure from the engine crankcase created by your pistons as they go up and down. As Mick stated in the other thread, oil transfer valve is not the proper term for this item. It was never intended to prevent too much oil in your primary.
FourCams's Avatar
Why would the crankcase vent into the primary? The crankcase has a breather on the oil pump and it vents through the cam chest doesn't it?
Are sure you're not talking about the "foo foo" valve?
If it's not the proper term, why would J&P, V-Twin, this forum, and every other Ironhead forum I've seen over the past 15 years refer to it as an oil transfer valve?
And why would the people who have plugged it not be having problems with engine seals if after they blocked it they vented the transmission and not the engine?
It makes more sense to me that it would vent from the primary into the crankcase - especially since there's a vacuum in the engine when the piston goes up and the crankcase breather is on the opposite side of the engine.
(I'm really confused)
Old 18th August 2009
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
+1 on that. There is a whole crankcase breather system timed on the oil pump and venting out past the generator drive. That oil transfer valve, whatever its purpose, is not to control crankcase pressure. No way is the crankcase breathing into the primary, which then breathes to atmosphere through a pin hole in the filler cap.
Which way is valve set up to flow? If someone has a set of cases around, can they see if the valve is set to allow flow from the primary into the crankcases or vice versa?
I always assumed it allowed oil to flow from the primary back into the crankcase if the sprocket shaft seal was leaking.
