0 Sportster or Street Bob
Last Post: RKN
0 Drive Chain Adjustment
0 Newbie CV rebuild
0 1977 xlch starter issues
Last Post: datimm09
0 no rear brake light
5 Transmission HELP!
Last Post: Twistedrench
0 Reflectors...Yeah, or Neh
Last Post: kap
0 Primary Chain Adjustment
Last Post: sltm1
0 Tachometer drive
Last Post: sleighcrane
Old 18th August 2009
Stick_Man's Avatar
Stick_Man Stick_Man is offline
Sportster/Buell Model: 1981 IronHead
Other Motorcycle Model: 1975 Aermacchi/H-D SX 175
Stick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura about
Default Strange Oil Bottle thing
I bought an '81 IH 2 months ago and I'm still in the process of going through the bike. There's this strange little bottle type thing on the bike; it resembles the little shot, hard liquor bottles you see on airplanes and hotel rooms. It has at least one hose running to it; probably 2 though. It's protruding down from under the bike almost behind my left foot.
The individual I bought it from told me he put it there as a precautionary measure to keep oil from ever getting on the rear brake rotor. It seemed like a good thing at the time. However, I notice when I sometimes give the bike too much throttle -- when warming it up -- that oil sometimes comes out of it. Otherwise I can't really tell if the bike leaks or not.
in any case, does anyone know what this thing is supposed to be?
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Sounds like a catch bottle for the crankcase breather tube/s coming from the front of the cam cover. Since this tube can drip or spew a little oil, the PO probably fitted a container to catch it.
Eric
SCAGNETTI's Avatar
SCAGNETTI SCAGNETTI is offline
Sportster/Buell Model: 1200XLCR
SCAGNETTI is on a distinguished roadSCAGNETTI is on a distinguished roadSCAGNETTI is on a distinguished road
It sounds like a home made catch can. Also, it's an '81 ironhead it leaks oil!, if doesn't leak oil you don't have any. Before EPA standards became so tough h-d's cases vented to the ground.
Ivan RoachCoach's Avatar
Banned
Default That's correct. And that's where it SHOULD be venting...
...not into any "catch can".
How the hell is that bike supposed to mark it's territoty, then?
69SPORTSTER 69SPORTSTER is offline
Sportster/Buell Year: 1969
69SPORTSTER is an unknown quantity at this point
NONSENSE.. it's the oil reservoir for the James Bond oil slick, when you"re being chased by the Po-leese...
What year bike? If it's the old style oil pump, it may not be timed correctly. That could cause the bike to wet sump and spew more oil out the vent tube than if the pump were timed correctly.
It could have a slightly leaky check valve on the supply side, causing the same problem. The ones I've seen that wet sumped from a leaky check valve were obvious. If it only catches a small amount, everything may be normal.
fergerburger's Avatar
fergerburger fergerburger is offline
Senior Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of light
post a pic of this thing....I have a catch can on a big twin motor...it should have a breather on it and some way to drain it....if it is the size of a "shot" size Jackie-D bottle, it's too small to do much good
Old 19th August 2009
NJ Ironhead's Avatar
NJ Ironhead NJ Ironhead is offline
Sportster/Buell Model: Xl ironhead
Other Motorcycle Model: Kawasaki kz650
Other Motorcycle Year: 1978
NJ Ironhead is on a distinguished roadNJ Ironhead is on a distinguished roadNJ Ironhead is on a distinguished road
post pictures.. id like to see the catch can idea. ive been thinking of something custom for my bike.. ive seen them before but id like to see what you guys have. no offense but i dont feel like having oil all over my rear tire.. my chances is i will roll overthe puddle i created.
"Volkswagens made me crazy, motorcycles set me free" Julio.M
southflasportster's Avatar
southflasportster southflasportster is offline
Sportster/Buell Model: 883 XL
southflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the roughsouthflasportster is a jewel in the rough
'06 Sporty 883XL, took some stuff off and made it loud.
Old 27th August 2009
Stick_Man's Avatar
It's an 81. What's a small amount? Although something is wrong -- it stalls and front plug is lean.
