Last Post: big andy
0 Brake Squeek
Last Post: Tucsonmax1
0 Won't rev past 1200
0 Value of a Boattail?
Last Post: Monte03
Last Post: Jowniofownio
0 Not charging issue!
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Mikuni HSR42
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
Old 19th August 2009
RonnieJ's Avatar
RonnieJ RonnieJ is offline
RonnieJ is an unknown quantity at this point
Default Lollipop Baffle
I know I will get increased back pressure using a homemade lollipop baffle in gutted mufflers or drag pipes but will it also quieten it down?
POW-MIA Riders
War Vet MC
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
Nope, won't help with that
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
pattywagon pattywagon is offline
Sportster/Buell Model: xlh/240 ridgid
pattywagon has a spectacular aura aboutpattywagon has a spectacular aura aboutpattywagon has a spectacular aura aboutpattywagon has a spectacular aura aboutpattywagon has a spectacular aura aboutpattywagon has a spectacular aura aboutpattywagon has a spectacular aura aboutpattywagon has a spectacular aura aboutpattywagon has a spectacular aura aboutpattywagon has a spectacular aura about
yea it tones it down some,just remember the old saying If its to loud your to old!!!!!!!!
RonnieJ's Avatar
Pattywagon that hurts, Yea I'm getting older but I'm more concerned with the neighbors. I lived in Alaska and no one cared but now I live in a neighborhood in Michigan that is quiet as a mouse.
Old 20th August 2009
Just poking fun hell I am 46 but I run 2 into 1 supertrapp header with the muffler removed and a turn out welded on with a lolipop in it.
Old 27th September 2009
bass thrasher's Avatar
bass thrasher bass thrasher is offline
Sportster/Buell Model: xl883
Other Motorcycle Model: honda xr250r
Other Motorcycle Year: 87
bass thrasher is on a distinguished roadbass thrasher is on a distinguished road
damn pattywagon, that super untrapped pipe looks awesome as hell. too bad you had to pay all the cash for the initial exhuast you arent using. i love the look of two-one with a collector turn out
'05 XL883
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
No probably not. I have Thunder Monster baffles, which are a fancy kind of the same thing and they don't cut down on the music.
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
Lollipops are for children, what you need is a real performance exhaust that works which means it will have a muffler that works. I wish everyone on here would read Aarons (asw racing) excellent thread on exhaust systems. Open pipes kill your power over 95 % of the rpm range, a lollipop helps a bit it's still like draging a boat anchor behind you. The baffles in the muffler do a lot more than just quiet things down.
Oli1200's Avatar
Oli1200 Oli1200 is offline
Oli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of light
I ran a set of those Big City Thunder torque ring insert things a few years ago. They just cut down on the raspy throttle roll off "blaaat" a little bit, they don't really cut down on sound compared to real baffles. Same would be for the lolly pop trick most likely.
Speaking of which, I must be getting soft. I had been running open straight headers for a few years until recently when I slipped in some standard 4" baffles to make Johhny Law happy. The other day I took them out to see what the sound was like again and I was surprised at how loud they were. I couldn't see how I rode for so long without baffles, I just got used to it. I put the baffles back in, they definitely give you a bit more on the low end to mid range, easier on the motor, easier on the neighbours, and they make you legal.
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
To each is thier own..not everyone still rides around with the stock seat while having the
stock reflectors installed on the front sliders..
