0 Ironheads
0 Salutations y'all
Last Post: Fridge
Last Post: Vohnsen
0 67 Sportster build
0 There’s shade tree brakes; then there’s the dark side of shade tree
Last Post: sdsbassist
Last Post: Grumpy-Biker
0 no rear brake light
Last Post: geoff
Last Post: goblin_dust
Old 15th May 2007
Jojo_Dogboy Jojo_Dogboy is offline
Sportster/Buell Model: 883 XLC
Jojo_Dogboy has disabled reputation
Default First Post - Ingnition Wiring Problems - 2001 883
Hello folks, I am also experiencing the Phantom Shutdown phenomenon. Bike gets hot shuts down. Cools off starts up consensus is bad ignition. So I bought a Crane HI-4E kit with Deutsch, 8-Pin Connector (since like every one else I plan a 1250). Damn plug is the wrong gender there is a male on the wiring harness and a male on the Ignition. Any one else put one of these on a 2001 883? Did you make a gender changer or re wire the ignition kit? Any one have this problem on a Daytona?
Old 15th May 2007
snowman's Avatar
snowman snowman is offline
Haven't had the problem but I thought I'd welcome you to the forum from Michigan
and bump you back up...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 16th May 2007
Thanks, the weather letting you ride?
