Ei
Last Post: cazz1000
Oil??
26th August 2009
Posts: 517 Sportster/Buell Model: XL 1200 Custom Sportster/Buell Year: 2003
All of a sudden ... pop, pop, popping
Last weekend a buddy and I went for a ride in the mountains. He bought an '02 1200S about the same time as I totaled my last bike and this was the first chance we've ever had to ride together (he's been lurking around here and I'm trying to get him to become a member). Mine is an '03 1200C with 10K miles that has run great for the first 300 miles that I've owned it.
After putting on about 100 miles I noticed that my bike was suddenly popping when decelerating. Now it does it all the time. Every time I let off the throttle it pops and pops and pops until I pull the clutch. Everything else seems to be the same: it starts right up, idles nicely, and seems to have plenty of power. But something has changed/moved/shifted because it hasn't had this problem since I bought it. She has a ThunderHeader 2:1 exhaust, stock carb with a Thunderslider and a Screaming Eagle air cleaner.
Any suggestions on where I should start looking for the cause? Could this be something as simple as loose connections at the manifold?
“When I’m riding my motorcycle, I’m glad to be alive. When I stop riding my motorcycle, I’m glad to be alive.” - Neil Peart
26th August 2009
Hmmm, I may have found my problem. When I installed my Pingel petcock, as with any non-vacuum petcock, I plugged the line to the carb. I just noticed that the plug is gone and the line that used to go between the stock petcock and the carb is open.
Could that be my issue (can't test this until the engine cools a bit)?
26th August 2009
Posts: 1,409 Sportster/Buell Model: 1200c Sportster/Buell Year: 08 Sportster/Buell Model #2: Xlh Sportster/Buell Year #2: 77
Check your exhaust bolts they are probably loose. It sounds like an exhaust leak to me.
"A man dies when he does not stand up for what he knows is right"
26th August 2009
Posts: 266 Sportster/Buell Model: 883xl<1200 Sportster/Buell Year: 08 Sportster/Buell Model #2: xlh 883 Sportster/Buell Year #2: 1986 Other Motorcycle Model: roadster xl1200r Other Motorcycle Year: 05
mine did that I foudn one of my exhaust bolts missing got a new one put some hifgh temp loctite no more problems
26th August 2009
Senior Master Bike Builder
Posts: 2,178 Sportster/Buell Model: XLH (ironhead) Sportster/Buell Year: '77 Other Motorcycle Model: Sold it!!
The missing plug is causing a vacuum leak. A lean mixture can cause your popping.
Murphy is my co-pilot.
26th August 2009
Wait...What?
Posts: 2,520 Sportster/Buell Model: 88 inch modified Sportster/Buell Year: 2003 Sportster/Buell Model #2: iforgot Sportster/Buell Year #2: 80's Other Motorcycle Model: crs Other Motorcycle Year: 80's
Is it hot where you ride? It was 107F today. How's it jetted?
Usually a gasket leak will cause the decel pops. The following items affect how the carb works:
Altitude.
Temperature.
Humidity.
Riding Style.
26th August 2009
It's typically mid-90's to 105 this time of year but it's been that since I bought the bike. The bike is relatively new to me and I don't know how it's jetted – only that it was re-jetted when the previous owner added the ThunderHeaders.
I'm going to close off that vacuum leak to the carb (this time with something more permanent) and take a wrench to my exhaust bolts. Hopefully it's something simple like that.
Thanks all.
26th August 2009
Posts: 9,943 Sportster/Buell Model: 1200 R Sportster/Buell Year: 2005
I belive plugging that vacuum leak will solve your problem. It's running LEAN with that baby sucking in all that air!
Stuff: YES
26th August 2009
Popping through the carb on accel is lean. Popping through the exhaust on decel is almost certainly an exhaust leak. Check for flange leaks, joint leaks, or a cracked collector on the Thunderheader.
I bought my Thunderheader because a craked stock pipe was causing pops and backfire on decel. I welded it twice and it broke again just past the weld.
26th August 2009
Chris.......I know when I was tuning my Mikuni and had de-cel backfires through the exhaust...it was too lean on the pilot....because the throttle was closed and it was just running on the pilot.
I think the Mikuni tuning manual even mentions that de-cel backfiring can be caused by a lean condition.
