0 TC88A maps for 1250 Sporty
Last Post: Yellowstone Kelly
Last Post: Diogenes415
Last Post: lugster
0 Feeling in trouble.
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
Old 2nd September 2009
RcRacer's Avatar
RcRacer RcRacer is offline
Sportster/Buell Year: 1981
RcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura about
Default Lowering my '81
I need to lower my ride at least an inch until I get get full strength back in my right leg and ankle. The stock eye to eye measurement for my '81 is 12.5". Does anyone know if Nightster shocks ( 11" eye to eye ) will fit? I have read that the height is not an issue but are the lugs the same etc?
1976 XL's Avatar
1976 XL 1976 XL is offline
Sportster/Buell Model: Sportster XL
Sportster/Buell Year: 1976
Other Motorcycle Model: Springer Softtail
Other Motorcycle Year: 89'
1976 XL is on a distinguished road1976 XL is on a distinguished road
Rc, I'm not sure on this,but I think the bushings are a different size. I think you can use the same size bushing and rubbers and make it work(not sure, haven't done that). My issue would be clearance between the fender bolts and tire. Although I'm not using 12.5 shocks either. Those would be a bit short for me. Good Luck Bro. Stay in the saddle, your doin' great.
NJ Ironhead's Avatar
NJ Ironhead NJ Ironhead is offline
Sportster/Buell Model: Xl ironhead
Other Motorcycle Model: Kawasaki kz650
Other Motorcycle Year: 1978
NJ Ironhead is on a distinguished roadNJ Ironhead is on a distinguished roadNJ Ironhead is on a distinguished road
a post recently where there was like a 2 page discussion about lowering my bike and my options..
"Volkswagens made me crazy, motorcycles set me free" Julio.M
RcRacer's Avatar
I read that thread. It did not answer my question. Thanks anyway,
Thanks for that info. I can fab the rubber grommets and bushings if that's all it takes.
for arguments sake could you safely space the top and the bottom of the springs.. to make sure for clearance. not sure if it can be done on a harley but i seen someone do this on a cafe racer to fit shorter progressive type shocks without hitting rear frame,bolts, inside tire or reardisk setup he had which seemed to get in the way.
he used a solid spacer thru the middle and either had it tapped so he could bolt on or welded dont remember.
but i agree on before i had a hardtail the nightster shocks seem like a great idea..
