0 Primary Oil INSANITY!
0 New member in MD
0 Decman's Birtday
Last Post: Outtakes
0 Oil??
0 Ei
Last Post: trappnman
0 What's your helmet?
Last Post: goblin_dust
Last Post: spacecoast
0 Rear tire
0 Salutations y'all
Last Post: cotton1
0 Show your tank decals
Last Post: cotton1
0 New England 2018
Last Post: joes95bobber
Last Post: cotton1
Last Post: Heff
0 67 Sportster build
Last Post: ldurmon
Old 2nd September 2009
casey jones casey jones is offline
Sportster/Buell Year: 1991
casey jones is on a distinguished roadcasey jones is on a distinguished road
Default Wont go over 65!!!!!!!!!!!!!!!!!!!!!!!!!
I have a 91 883 stock except for a K&N filter and V&H pipes. All of a sudden it wont run over 65 mph. It seems like only 1/4 of the trottle is working. Anything over that it just seems to bog down. Could it be the slider in the carb stuck, or the diapham maybe? HELP Stuck in the slow lane
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
sounds like its starving for fuel. chect petcock filter then go inside the carb
the females are fixing my old XL for fathers day . its a ford not a harley but its mine, MINE !!!
dr.feltersnatch's Avatar
dr.feltersnatch dr.feltersnatch is offline
Sportster/Buell Model: 1200c
Sportster/Buell Year: 08
Sportster/Buell Model #2: Xlh
Sportster/Buell Year #2: 77
dr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud of
I agree sounds like a fuel flow issue pull the fuel line and check for flow if its not a solid stream check your petcock and then the filter. If you have good flow time to clean the carb
"A man dies when he does not stand up for what he knows is right"
ron521's Avatar
ron521 ron521 is offline
Sportster/Buell Model: 883
ron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really nice
Sounds like main jet is stopped up, running on pilot jet. When throttle opens too far, mixture goes lean because pilot can't supply enough fuel.
Old 3rd September 2009
I found it. The diapham has a small crack in it. Looks like whoever put it in got a small wrinkle in it and it just wore a hole in it. Without that working properly the slider will not move and was staving for air. Thanks again for the input. Casey
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
Glad you found it! Drop in a new piece and ride on.
