0 New in NM
Last Post: Vohnsen
0 C.O.B.B run west
Last Post: Zoharo
0 Kickstand identification?
Last Post: cotton1
Last Post: Vohnsen
Last Post: sltm1
0 What's your helmet?
Last Post: Wharfcreek
0 04 sportster custom 883, turn signal module (TSM)
0 Silverado Power lock issues
Old 21st April 2005
Kev12012 Kev12012 is offline
Kev12012 has disabled reputation
Default when to shift???
I know that this has probably been answered a thousand times but I am going to ask it again anyways???? can anybody out there that has a tach on their bike tell me about what rpm's to shift???? and about what rpm's you should be on the highway at about 70???? I am sort of new to the whole harley thing.... after riding high rpm jap bikes it is a big difference to me.... by the way I have an 883-1200 with the 883 front sprocket still in...
Old 21st April 2005
Y2K's Avatar
Y2K Y2K is offline
Other Motorcycle Model: Electraglide classic
Other Motorcycle Year: 2000
Y2K has disabled reputation
Shift when it feels good lol.Harleys pull well from about 2500rpm til around 4500rpm in stock form.That's the beauty of the H/D motors wonderfull linear torque curve.Just don't lug it down till it jerks or wind it out past where it's still pulling well.
Y2K
Electraglide Roadtripper
Old 21st April 2005
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
You can go to http://people.montana.com/~bowman/Sp.../SpeedCalc.htm for a rpm calculator for early and late (pre '04) 883's, 1200's and more.
When to shift depends on how your 883/1200 conversion was built and how you like to ride. I'm assuming you mean at what rpm to shift when racing??? IF so, then we would need more information on what has been done to your engine to determine a close estimate. OR a dyno sheet.
If you have an '04 or up bike, then you can use this rpm calculator http://www.geocities.com/z_design_st...ion_z28_6.html and just plug in the correct information. In your case it would be a 150/80/16 tire, set transmission ratio's to 1:1, and set rear gear ratio to 4.071:1 and that will give you 5th gear rpms at any speed.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Old 23rd April 2005
thereisnospoon's Avatar
thereisnospoon thereisnospoon is offline
thereisnospoon is an unknown quantity at this point
just cruising I'll shift at 1800 to 2200 depending on gear... probably short shifting compared to a lot of people. any lower and it sounds like the rod bearings are being beaten flat.
Old 24th April 2005
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
OK, this threads been beaten to death....lol
When you should you shift? When it sounds like somethings gonna break apart if you don't!
lol
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 24th April 2005
Chuck's Avatar
Chuck Chuck is offline
Sportster/Buell Year: 03
Other Motorcycle Model: Elecectra Glide Classic
Other Motorcycle Year: 2010
Chuck is an unknown quantity at this point
Most probably shift in the high twos to low threes. Nice flat stretches if you want to knock down the vibes, noise and go easy on gas you can cruies in the twos.
2010 FLHTC
Old 24th April 2005
TechRep's Avatar
TechRep TechRep is offline
TechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of light
You should be at about 3500 RPM at 65 MPH.
Old 24th April 2005
Chuck's Avatar
"and about what rpm's you should be on the highway at about 70????"
Well at 70 it doesn't really matter. It's whatever it is in 5th gear, that is if your not racing. I can't remember what mine is cruising at 70 but someone will let you know. Do a search too, there is plenty here and online.
Similar Threads
Zippers Red Shift 567 cams and RB Racing “LSR” 2-1 exhaust > NEW Turbota Sportster Motorcycle Motor - Top End 49 27th May 2005 03:07
? converting 74 to L side shift??????????? NJDevildog Ironhead Sportster Motorcycle Talk (1957-1985) 3 29th April 2005 15:45
Clunk every shift?? rambo Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 12 27th April 2005 21:17
Red Shift 567 cams > Turbota Sportster Motorcycle Motor - Top End 5 26th March 2005 00:09
Shift Gauge? schvamf Sportster Motorcycle Motor - Top End 75 1st March 2005 20:40
