0 1972 tank fitment
Last Post: 72 Ironhead XLH
0 Blues & Brews 2018
Last Post: tvon
Last Post: tvon
0 Help me with gas cap...
Last Post: geoff
0 Turn signals
0 bike went for a slide
Last Post: chevelle
0 Cad Plating
Last Post: DirtyHarry68
Old 12th September 2009
1982ironhead's Avatar
1982ironhead 1982ironhead is offline
Bike Builder
Sportster/Buell Model: xlh1000
Sportster/Buell Year: 1982
Other Motorcycle Model: Triumph
Other Motorcycle Year: 196x
1982ironhead is on a distinguished road1982ironhead is on a distinguished road
Question why isnt this Super B a 45mm venturi carb?
borrowing a friends carb off his 79 1200(stroker?) sportster that has sat the last 5 years, it sat in parts cleaner overnight to clean it up, but i was wandering if they made 40mm versions? it is 40mm at the smallest point and looks real old, it had Super B stamped on the side though, so whats up with that (only 40mm)?
72Iron's Avatar
72Iron 72Iron is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: Harley-Davidson
Other Motorcycle Model: FLHTCU (Geezer Glide)
72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice
The Super B is a 1 7/8 carb, which equals to 47.625mm.
S&S Uses SAE measure, not metric.
I gave up smoking, drinking and sex.
It was the worst fifteen minutes of my life.
RIP: Eli
Bike Builder
most other carbs are metric and the S&S booklet lists it as a 45mm venturi (the smallest part about half way down the bore)
i just thought it was weird that it is a B but only 40mm, were the early models different or is there any varience to the b models at all?
72Iron's Avatar
Introduction
S&S® Super B carburetor is a butterfly type carb with a fully
adjustable idle mixture screw and changeable mid range and
high speed jets. This carburetor does not have an accelerator
pump nor a conventional choke, but utilizes a mixture
enrichment device for starting. The Super B has a 17⁄8” (47.6mm)
throat at the butterfly and a 19⁄16” (39.6mm) venturi and is
identified by an “B” cast into the throttle return spring side of
the carb body below the cast in wording “S&S SUPER”.
http://www.sscycle.com/admin/uploads...ns/51-1006.pdf
Most other carbs aren't made in the USA.
What book are you refering to?
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Most carburetors are sized by the diameter of the throttle butterfly, not by the size of the inner venturi, e.g. a 40mm Weber DCOE has 2 40mm brass butterflies while the actual venturi size is smaller.
Eric
Bike Builder
well i tried on the Super B and it ran pretty good, i just found out the other bike was not a 1200 but a 1000 like mine, after setting the idle speed and fuel mixture it ran pretty good, but not much better than my bendix, which i measures as a 36mm last night. throttle controll is important with this carb, about 1/4 is all that you need up till 4000+rpm then roll it on fast! it pulls a little better burnout but i doubt it would gain me any more than a few tenths or so in the 1/8th mile. i might see 8.8-8.9.
well i figured my issue was the condenser, mostly, the bendix had some issues as well. but i got the dyna s coming monday or tuesday and now i know it was just my points setup causing issues i can confidently install the dyna without worry of frying it.
the booklet im refering to is the S&S one dad got with his Super E which also covers the Super B a little
Bike Builder
looks a lot like the booklet in your link except it has the Super E also
just looked at it it is a 44.5mm venturi...... for the super "G" sorry my mistake!
