Last Post: MCCoy
0 What's your helmet?
Last Post: Hellbent_4
Last Post: sltm1
0 The Welsh Way, 21st April 2018
0 Show your tank decals
Last Post: kap
0 Tuning
Last Post: XLXR
0 Spokes or Mags
0 New in NM
Last Post: spoon
0 Hi 4 ignition rotor gap sensor broken off
Old 23rd September 2009
dsk1000 dsk1000 is offline
dsk1000 is on a distinguished roaddsk1000 is on a distinguished road
Default Restoration - Paint or Powder Coat
So, I'm soliciting opinions on whether to paint or powdercoat a 1975 XLCH frame for a restoration.
I believe some feel that since powder coating was not used in 1975, the frame should be painted. However, I believe frames then were coated using "stove enameling" which I believe is rare to find. So, painting with wouldn't be all that authentic either? Perhaps someone knows what process was used to paint these frames.
I have been told that many credible restorers are powder coating old frames.
All opinions welcome. Thanks.
Doug
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
i think powder coat is somewhat more durable but theres no real touch up, where as painted could be touched up after fitting the motor and such and look good.
my .02
the females are fixing my old XL for fathers day . its a ford not a harley but its mine, MINE !!!
meanmechanic's Avatar
meanmechanic meanmechanic is offline
Sportster/Buell Model: sold XLH
Sportster/Buell Year: 1972
Other Motorcycle Model: VRSCR + BMW R1200C
meanmechanic is on a distinguished roadmeanmechanic is on a distinguished roadmeanmechanic is on a distinguished roadmeanmechanic is on a distinguished road
How much of a restoration is this? If it's a true resto. then it's paint. If it's a refurbish for yourself, powdercoat is the way to go.
JimInNY's Avatar
JimInNY JimInNY is offline
JimInNY is on a distinguished roadJimInNY is on a distinguished road
Anything I ever owned that was powder coated eventually rusted under the coating, like my Dodge truck bumpers. I wouldn't powder coat anything, ever. I used epoxy urethane on my frame 9 years ago and it still looks like new.
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant future
if you are restoring the whole bike to original condition, then paint it. a good enamel will give you a finish close to the original. Joestuff sprayed his '62 with a high quality enamel from a spray can and it looks pretty darn good.
if by restore you really mean refurbishing, then do whichever you prefer.
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
+1 on this! I can't tell you how many things I've worked on that were powdercoated and had the coating peeling off due to corrosion underneath. I'll never powdercoat anything I own. High quality urethane paint is the way to go.
Eric
Thanks. I am shooting for restoration. If anything must fall short of a full restoration for now, I want my options open to complete it in the future. Hence, the decision on the frame coating.
Does anyone have any paint recommendations for an industrial polyurethane?
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
Well I guess if your going for a 100 point restoration your going to have to paint it. I think for the fellow members whose powder coating peeled it was probably bad preparation by the coater. The motor company frames are all powder coated these days so it's safe to say that if it's done right it will last.
Here is a picture of my '75 XLH frame which I think came out beautiful after powder coating.
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1957
Other Motorcycle Model: KH KHK XLH XLCH
Moon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant future
Who are these reputable restorers? If you are going to restore the bike, paint it--period. In fact, I've spoken recently with two AMCA judges who say that they are going to start docking points for base coat-clear coat. I would go one of two ways. If your painter is doing it, go with a single stage urethane, 80% gloss on the frame. If you're doing it yourself (highly recommended) buy a can of good black epoxy paint. A lot of top shelf restorers actually prefer the spray can method (frames only) because they are so easy to retouch.
As 64xlh mentioned, take a gander at Joestuff's gorgeous 62 high-point restoration. His frame paint job came out of a poof can, and it looks great.
1976 XL's Avatar
1976 XL 1976 XL is offline
Sportster/Buell Model: Sportster XL
Sportster/Buell Year: 1976
Other Motorcycle Model: Springer Softtail
Other Motorcycle Year: 89'
1976 XL is on a distinguished road1976 XL is on a distinguished road
My frame was powder-coated when I bought it. It is very durable, but I think you will have to tap all threaded holes, and make sure your grounds make contact to the frame. When I get chips in mine,I touch it up with enamel paint.
