Last Post: gravydog
0 Sportster or Street Bob
Last Post: Baby883
Last Post: RKN
0 New member in MD
0 19" to 21" sportster front wheel finally done and installed
0 Rear tire
0 Salutations y'all
0 Overheating after cams and headwork
0 Decman's Birtday
Last Post: O.R. John
5 Transmission HELP!
Last Post: Blowupster
0 Oil??
Old 30th September 2009
jrwca's Avatar
jrwca jrwca is offline
Sportster/Buell Model: XL 883 Deluxe
Sportster/Buell Year: 1991
jrwca is an unknown quantity at this point
Default Buell intake manifold
Is there any reason an intake manifold from a Buell Firebolt Lightning XB9S won't bolt up to a rigid Sportster engine?
I imagine it should fit just fine if the the rubber mount intakes fit, right?
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
You do realize the XB intake runs vertically, right? And that it uses a throttlebody instead of a carb? To clarify, the XB intake runs straight up to the airbox (where most fast tanks are) because XBs have fuel in the frame and the frame runs where a sidedraft intake, e.g. Sportster style, would mount.
Love is the never-ending act of forgiveness - Peter Ustinov
jrwca's Avatar
That's part of what I was trying to figure out. I thought they ran up at an angle and not straight up.
Thanks.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Sportster/Buell Year #2: 2016
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
Thanks.
Buell relocated the fuel tank in order to run that system. What you see on the XB series that looks like a fuel tank is nothing but a plastic air-box cover. The ACTUAL fuel tank is the structure inside the frame (i.e. they FRAME is the fuel tank).
Now that said, I suspect the XR EFI intake may be similar, and that is what necessitated the new air intake for the XR (but there are tank differences on the XR as well).
would be very difficult to run an XB injection system on a Sporty as it would hit the fuel tank big time!
jrwca's Avatar
Yeah, for some reason I was thinking it was at an angle which I wouldn't mind working with. But straight up is a problem.
I'm going to look at the X1 stuff.
Phelan's Avatar
Are you trying to fuel inject your bike or what?
jrwca's Avatar
That's the idea. I've been toying with the idea for a few years now. I have a few things planned for my bike and it's going to require a rewire. I want to make sure I think of everything I might need to allow the swap to FI later.
Phelan's Avatar
Just pick up all the parts from an X1 or '99-'02 S3T and weld an O2 bung into your header. Besides the wiring and ECMspy programming, it's pretty much a straight-forward swap in a solidmount sporty.
