0 THE Trainspotting Thread
Last Post: gravydog
0 Sportster or Street Bob
Last Post: Baby883
Last Post: RKN
0 New member in MD
0 19" to 21" sportster front wheel finally done and installed
0 Rear tire
0 Salutations y'all
0 Overheating after cams and headwork
0 Decman's Birtday
Last Post: O.R. John
5 Transmission HELP!
Old 25th April 2005
bdjhog02's Avatar
bdjhog02 bdjhog02 is offline
Sportster/Buell Model: Hugger 883/1200 conv
bdjhog02 has disabled reputation
Default '86 Heads on 2003 cylinders
Other than the breather bolt situation is there any reason why I couldn't put a set of '86 883 heads on a pair of 2003 883 cylinders? I have the opportunity to pick up these "bathtub chamber" heads for $225. I just bought the 2003 cylinders from Ebay and was planning on sending everything to Nallins for a 1200 conversion with a Stage 1 P&P job. BTW, this will all be going on a 2002 Hugger with the addition of a set of Andrews N2 cams.
Brian
Old 25th April 2005
Y2K's Avatar
Y2K Y2K is offline
Other Motorcycle Model: Electraglide classic
Other Motorcycle Year: 2000
Y2K has disabled reputation
How is your engine going to vent?
Electraglide Roadtripper
Old 25th April 2005
bdjhog02's Avatar
I guess I'd have to run a crankcase vent line somehow like they used to have on the pre-breather bolt heads. I guess that's what I'm asking here.
Brian
Old 26th April 2005
happyman happyman is offline
happyman has disabled reputation
Brian
they can drill those heads For the breathers very easy. i also have a set of them. thinking bout getting rid of them too. won't need them now.
Old 26th April 2005
HD1200R's Avatar
HD1200R HD1200R is offline
Sportster/Buell Model: XR1200x
Sportster/Buell Year #2: 1993
HD1200R is an unknown quantity at this point
I'm running 86 heads on mine too. I drill the vent hole that runs through the cylinders and heads and then the hole tat goes from the heads to the air cleaner. I had to shorten the original air cleaner bolts too.
1993 Harley Sportster 1200cc
2011 Harley Sportster XR1200x
Old 27th April 2005
supposedly these are a decent head to make tq and hp but i am sure there sponcers here that can do as good with the sportster or buel heads or better perhaps. not an expert by no means but i guess the 86 heads do make the ##'s
Old 27th April 2005
HD1200R's Avatar
I got lucky and dad already had a set of P&P 86 heads. I don't know about creating better numbers though. I always saw them as standard 883 heads that were modified.
The best bang for buck would be the Nallin Racing XB12R heads fully assembled without the porting. You get awesome results with not going over $1000! If you want them opened up some and modified, expect to spend at least a grand on heads and work.
Similar Threads
Holding down the jugs when the heads are removed? Turbota Sportster Motorcycle Motor - Top End 15 26th April 2005 00:23
1200 heads and valve job bdjhog02 Sportster Motorcycle Engine Conversions 18 14th April 2005 15:45
s/e heads harleymanjay04 Rubber Mount Sportster Motorcycle Talk (2004-2006) 2 2nd April 2005 21:04
883 Heads What do I do.... connorleeneil13 Sportster Motorcycle Engine Conversions 21 23rd February 2005 14:56
883 Cylinders and Heads doc Sportster Motorcycle Engine Conversions 5 22nd November 2004 01:12
