Last Post: Martysf
0 Solar battery charging
Last Post: drumbrake
0 Iree's jukbox joint
Last Post: rubine
Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
Old 13th October 2009
1982ironhead's Avatar
1982ironhead 1982ironhead is offline
Bike Builder
Sportster/Buell Model: xlh1000
Sportster/Buell Year: 1982
Other Motorcycle Model: Triumph
Other Motorcycle Year: 196x
1982ironhead is on a distinguished road1982ironhead is on a distinguished road
Default cam cover off, what else to check while its open?
checked the end play before i took the cover off
#1-.015
#2-.015
#3-.015
#4-.005
all have shims, paper thin shims! i measured from behinde the dog bone looking thing and between the cam and dogbone, about the same endplay measurements but much more consistent from behind the dogbone
im also wandering where the stamping that would be either a p or q is, on the backside of the cams? i dont see a #1-4 either. all the timing marks line up,cant see for sure on #1 & #3 though since # 2 & #4 cover them up
Bike Builder
also, 1 and 3 have a green paint mark, 2 has a white paint mark and 4 has a blue paint mark, what are the colors for, didnt see this in the book....
Sportster/Buell Year: 1972
Shims are commonly .005" and .007" thick. #4 clearance is too tight. .015" to .020" seems to work for me, no chewed up shims, no excessive noise. Believe '82 had Q cams stock, not sure how they are marked.
Bike Builder
which side are they normally marked on?
The side facing away from the engine is what I've seen marked on older Harley "P", Sifton Hustlers, and Andrews "PB" cams, visible after you remove the cover and any shims on that end of the cam.
Ivan RoachCoach's Avatar
Banned
Default Cut that cam cover down now that you've got it off...
...Besides looking good, your oil pump will appreciate the extra air.
Bike Builder
yup they are Q cams, arnt these about the weakest/smallest cams Harley ever put in the 1000cc XLH's?
Bike Builder
if this is true, then why does my manual instruct to shim to .001-.005?
Jason's Sporty's Avatar
Jason's Sporty Jason's Sporty is offline
Sportster/Buell Model: Sportster XLH 883/1207
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1972
Jason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to behold
Check the breather valve in the cam cover. Its cheap insurance against puking oil all over the place.
Bike Builder
it Is in pretty great shape thanks though.
