Last Post: ezmerf
0 Lowboy frame conversion
Last Post: yoshi
0 What are you drinking tonight?
Last Post: ABMI
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 Need FP3 map for 2014 Sporty 1200
Last Post: tester
Last Post: Aden
Old 20th October 2009
fergerburger's Avatar
fergerburger fergerburger is offline
Senior Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of light
Default 74 versus 75 frame/cross-tube
Can I run 74 foot controls with a 75 frame? Are the frames for 74 and 75 the same castings? Is the cross over tube the same? I want to run right side shift on my 75 (using my 73 motor and parts).
Gone Gone is offline
the frames are the same. the cross over for the shifter on your 75 is the cross over for the brake on 74 and earlier. you will need the 74 and earlier brake cross over shaft and lever, the rod from the shaft to the brake lever on the drum, and a mount for the brake light switch will have to be fabbed, unless you get a 74 or earlier swingarm with the switch bracket on it. i believe the brake backing plate is different also, to accomondate the cable rr brake used in 75
Sportster/Buell Year: 1972
You also need to remove the trans to install the longer '74 and earlier shift shaft and lever.
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1957
Other Motorcycle Model: KH KHK XLH XLCH
Moon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant future
The backing plates are different, but you can make the one you have work.
