0 New from Utah
Last Post: XLXR
0 Not measuring any crankshaft endplay
Last Post: nakina
0 Manifold Leaks Gone !!!!
Last Post: cazz1000
Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
Old 22nd October 2009
Turbota's Avatar
Turbota Turbota is offline
Default Check these shock specs .. Seem Correct?
Is there a data base here on the XLForum that gives some of the specs of the various rear shocks?
I am interested in the comparison between the stock 04 1200R vs the 1200S rear shocks. I included the Ohlins on the bottom becuse I am considering these right now.
This is the info I have got, but don't know how acurate it is:
04 1200R Rear Shock:
13.25" Long
Spring Rate: 69 -116 lb / in
Stroke: 2.1"
1200S Rear Shock:
13.5" Long
Spring Rate: 54 - 78 lb / in
Stroke: 3.5"
Ohlins 36PL Rear Shock:
13.2" - 13.6" Long (Adjustable)
Spring Rate: 86 - 137 lb / in ... (this #03 spring seems about right for my bike and rider weight)
Stroke: 3.9"
04 XL 1222R
whittlebeast's Avatar
Other Motorcycle Year: 2008
13.25" Long
Stroke: 3.25" as it hits a fairly firm bump stop
1200S Rear Shock:
13.25" Long
Stroke: 3" as it hits a fairly soft bump stop
Do a search for spring database from about two years ago for the spring rates. Both of those shocks have stock springs that are fairly soft for most applications.
AW
P.S. Nice bike in the Pic
Turbota's Avatar
The reason I said the 04 XL 1200R rear shocks had 2.1" of stroke was because that's what it said on the H-D website for the bike back in 04.
XLXR's Avatar
XLXR XLXR is online now
Harley database of springs and shocks
I haven't read this thread in a long time, so I can't remember what is on it. There is a lot of infomation about shocks in the link in my signature.
http://www.hardracing.com/
A few guys have bought Ohlins shocks from Hard Racing, all were pleased. Contact them for spring and shock suggestions.
http://xlforum.net/forums/s...d.php?t=632187
Contact Shoei in this link, you guys need to exchange shocks.
These are ballpark spring rates for a sporty with about 3" total shock travel. These assume fixed spring rate. You can split the difference when running duel rate springs.
a 100 lb rider needs 77.5#/in springs
a 150 lb rider needs 89.3#/in springs
a 200 lb rider needs 101#/in springs
a 250 lb rider needs 113#/in springs
a 300 lb rider needs 125#/in springs
a 350 lb load needs 147#/in springs (assumes that this is a 200# driver with a 150# passenger)
