0 1967 XLCH stroker project
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 New to Harley
0 79 ironhead
0 THE Trainspotting Thread
0 rpm jump pulling in clutch
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
0 Value of a Boattail?
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
Last Post: jammantoo
Last Post: lugster
Old 23rd October 2009
fix3890 fix3890 is offline
Sportster/Buell Model: 1200 Roadster
fix3890 is an unknown quantity at this point
Default Starter specs. Does size matter?
Thinking about upgrading my starter to a shiny new Terry. Been highly recommended by a couple of my friends. But which one is right for me? They come in 1.2, 1.4 and 2.0kW versions. The 1.2 kw is supposed to be a stock replacement, but why wouldn't i go with the 1.4kW since it's the same price? Is there a disadvantage? More strain on the battery? Harder on the motor?
Your advice is appreciated. Anyone had experience with these starters? Thanks, everyone.
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
Curious if the old starter was bad or are you just swapping to be swapping?
I'd think the higher rated starters are for needed torque in modified engines.
Call the tech guys at www.jpcycles.com
They can help you out.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
Gone Gone is offline
As long as the fit is the same why wouldnt you want to go with a stronger starter? I would beef up the pos and neg cables, but thats a good idea anyway.
Default That's what i thought
Exactly. Plus, the 1.2 kW and 1.4 kW models are exactly the same price. Is there a downside i don't know about? Maybe someone here knows...
Oh, and my starter is occasionally doing the dreaded "clunk" and it's getting worse. Wanna get parts together before is get stuck with the bike down for weeks.
DEEP DIVER's Avatar
DEEP DIVER DEEP DIVER is online now
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
The 1.4 kw starter will have a bit more torque than the 1.2 kw.
This will spin the engine over easier, not faster.
The 2 kw has more torque for hi comp engines, you would only require this starter if you had done a lot of work on the engine[UP TO STAGE 3]
The 1.4 kw would not load the cables or the battery any more than the 1.2 kw would.
At work we have mazda LPG fork lifts with two starters.
A low power and a high power
If we fit a low power it lasts no more that 6 months,
the high power one lasts at least 12 months?
But we fit what ever the customer wants?
I would go for the 1.4 kw motor
toe's Avatar
toe toe is online now
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
FYI, the starter in my toyota truck (22RE 2.4l) is 1.0kw and is of the same type as the sportster starters.
The heavy duty version is 1.4kw
FYI2, still have original starter after 23+ years, only needed to change solenoid contacts. (relubed it when I had it apart)
Ed
The Only Y2K dual-set 883C
So Cal
Old 28th November 2009
rodhotter rodhotter is offline
rodhotter has disabled reputation
the draw on the battery should be considered since our sporty's have a minimal charging system and a small battery
Redhotter: thanks.
