0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 23rd October 2009
GoodSport's Avatar
GoodSport GoodSport is offline
GoodSport is an unknown quantity at this point
Default Starter Issues???
hello all,
as of (recently) i'm getting an obnoxiously loud KA-CHUNK when i hit the 'start' switch. just seems to happen when hot...like on re-start after gassing up. looking thru the shop manual, i'm guessing the starter pinion gear somehow isn't properly meshing with the clutch ring gear....wassup up wit dat???
any ideas?
thanks,
GoodSport
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Join the club. Read this Sticky here: http://xlforum.net/forums/s...ad.php?t=39646
Sic Semper Evello Mortem Tyrannis
Old 24th October 2009
elkgrick's Avatar
elkgrick elkgrick is offline
Other Motorcycle Model: electra glide standard
elkgrick is on a distinguished roadelkgrick is on a distinguished roadelkgrick is on a distinguished roadelkgrick is on a distinguished road
Originally Posted by GoodSport View Post
hello all,
any ideas?
thanks,
GoodSport
I've owned 8 HD's off and on since 1972. Have had this issue with every HD I've owned at one time or another. Sometimes a low battery will cause it. Even with a new starter and good battery it will still happen. Just the nature of the beast.
You guys get a fix for this let me know. I've been dealing with this for 35 plus years, never have found a fix for it.
Rick, Sacramento
Oli1200's Avatar
Oli1200 Oli1200 is offline
Oli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of light
I've always had an occasional harsh clank sound when starting hot. It's worse with a solenoid push button start like I use, just the way it is I guess.
GoodSport's Avatar
Default Starter Issues (cont'd)
thanks guys,
sounds like this is not by any means an isolated issue...s'pose i forgot to mention...my Sport is an '04 883 converted to 1200. if my (somewhat impaired) memory serves, i started to notice a (not so) occasional hesitation on crank-up around then...like not enough 'oomph' to get past 1st compression, then normal fire-up. i've got just over 20K on it now, and have just in the last 1500mi or so been hearing that 'KACHUNK' thing.
still have the original battery so it may well be a battery-current/solenoid thing.
definitely sounds like gears not properly engaging.
i'm thinking i'll be replacing the battery during or after this winter...to be continued.
thanks again.
GoodSport
Old 25th October 2009
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
One thing that helps......just bump the button when hot........then hit it a 2nd time....helps avoid that nasty noise and should start ok then.
Stuff: YES
