Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
Old 27th October 2009
sblackford sblackford is offline
Sportster/Buell Model: xlch 1000
Sportster/Buell Year: 1973
Other Motorcycle Model: Victory Hammer
Other Motorcycle Year: 2007
sblackford is an unknown quantity at this point
Default Oil Transfer Valve 73 Ironhead
I'm getting engine oil over in the primary side. I have been unable to find the location for the oil transfer valve that I would assume is the first thing to check. Any hint as to the location?
RRB RRB is offline
Sportster/Buell Year: 1966
RRB is on a distinguished roadRRB is on a distinguished roadRRB is on a distinguished roadRRB is on a distinguished roadRRB is on a distinguished road
It's just behind the primary drive sprocket. Check out this thread:
http://xlforum.net/forums/s...r+valve&page=2
If getting engine oil into the primary cannot be caused by the oil transfer valve, how is it most likely getting there?
Gone Gone is offline
its not supposed to get by the valve, though it seems it always does. its quite a common problem, that the valve fails and fills your primary full of oil. check out the stickies on it, some guys block it off completely, though i cant recommend that. its actually a one way valve to allow air into the crankcase from the primary when the pistons are ascending to help with scavenging the oil in the cases. it is my opinion that if that valve is blocked it increases pumping losses, by forcing the pistons to pull against a vacuum.
Ivan RoachCoach's Avatar
Banned
Default Guys have been blocking it for decades with no performance issues whatsoever...
...It's a simple procedure that anyone can do.
You can either weld it shut or block it off by tapping the valve's center orifice for threads and then inserting a brass screw into that orifice.
Once it's in there, covered with permanent-strength Loctite, simply distort the screw's head by peening it.
Sportster/Buell Year: 1972
Another path for engine oil to get into the primary is a failed sprocket shaft seal
oh yea, theres that too
How difficult is it to replace the valve? The cost seems minimal.
Banned
Default It's a royal pain in the ass to get one out...
...which is part of the reason 99.9 % of guys just weld or plug them up.
- SPORTSTER -
Kicking Big Twins in the motherf******g NUTS since 1957
CTFS/QCB
Viva Los Bastardos!!!
To replace it you have to pull the primary drive. To get it out you have to unscrew it. It is staked in place to prevent it from loosening. I got mine out by drifting it around in a circle with a punch. It was a pain.
