0 Stock 883 cold blooded
0 1977 Bright Blue
0 Not charging issue!
Last Post: Jowniofownio
0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
Last Post: jammantoo
Last Post: lugster
Last Post: lugster
0 79 ironhead
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 28th October 2009
DogBunny's Avatar
DogBunny DogBunny is offline
Sportster/Buell Model: XLH883-1200 Ol Black Mare
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Yam. XS650 "Angry Hornet"
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Yam. XS650 "Bug Killer"
Other Motorcycle Year: 1976
DogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to beholdDogBunny is a splendid one to behold
Default 1990 CV carb rebuild question -- what the heck???
Okay, so the manual says to back out the main jet and the needle jet holder. I have done that, they are resting on the right side of the body and in the float bowl in the pic. Manual then says:
"Needle jet is free to be removed from bottom end of passage."
But I have a brass rod in the way (red arrow). What the heck? I gently grabbed the rod with needle nose pliers, and very gently pulled, but got nothing.
Can someone please explain what is going on? I don't see that brass rod in any diagrams. Is it supposed to be part of the needle jet holder? Should I get more aggressive with the needle nose pliers? And if I pull the rod out, I still don't see any screwdriver slots at the bottom of the bore to back the needle jet out with.
Thanks.
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of light
The mid-range metering needle comes out from the top. the top of the carb where the vacuum piston (slide) is located needs removed. you will find a spring setting on a little plastic piece on top of the needle, however when the slide comes up the needle will too. also under the carb is a low speed adjustment needle, its behind a plug. (some drill the plug out so it can be adjusted)
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
shotgun46's Avatar
See if this helps
Sportsters Rule ! :banana
shotgun46's Avatar
and another
DogBunny's Avatar
Okay, I'm an idiot, thanks to both of you for the help.
One last little question.
In kdarejr's diagram, part #7, the "jet needle" -- right where the little #7 pointer thing is pointing to it near the top -- there is a c-clip with three tiny washers or shims stacked on top. Does that sound like stock? Or do you think someone has added washers? There are 6 possible little grooves that the c-clip could be fitted into. It seems like the c-clip could have just been moved up a grrove, and a couple of the shim washers could have been eliminated.
Thanks
xHDrider's Avatar
Thanks
mine didn't have the clip option. some shim up the style I have, I didn't choose to.
DogBunny's Avatar
Thanks.
Final (hopefully) question:
Under the accelerator pump nozzle -- # 42 in kdarejr's pic -- there is an o-ring, part #45. The Clymer manual says to remove, clean, and blow out the nozzle. How do you remove the accelerator pump nozzle to do that and to replace the o-ring? I have tried unscrewing it, and just pulling it straight out. I'm about to damage it.
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
I am not aware of any stock CV carbs coming with and adjustable needle so your needle is likely aftermarket. If they did that then they likley drilled the slide hole a little larger and put in a lighter spring on the diaphram. You may want to look at the needle carefully for wear in the midrange as many aftermarket needles wear quickly. What was the reason for the carb R&R?
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
DogBunny's Avatar
The reasons for the r&r were a cracked plastic fuel inlet elbow -- that requires removing the carb from the bike -- and gas leaking from the float bowl overflow tube. I found no dirt under the float needle valve, but the rubber looked worn. Maybe it's the float level. That's all -- I figured as long as I had the carb off, I'd re-build it -- the bike has done lots of sitting for the last three years.
Any one know how to remove the accelerator pump nozzle?
xHDrider's Avatar
if your talking about the pump spray nozzle, I have never removed mine. some people turn them, I checked my spray direction and did not turn it, if you did turn it make sure its directed right down the middle of the carb toward the bottom of the butterfly.
The pump rod will slide back into the pump body and boot easily or the re-assemble. don't take more then you have to apart. keep every thing clean. use compressed air to check passages.
