0 Vintage sportster saddlebags?
Last Post: jordan1200
0 03 xlh 88"
Last Post: conv90
0 Hello from Minnesota
Last Post: 1HD4CJM1X4K
0 Hello from Vegas
0 Lithium battery earthx
Last Post: jharback
Last Post: toe
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 This Mikuni vm38-9 is driving me insane
Last Post: cazz1000
0 Were your parents anti bike?
Last Post: jcn59
0 New Fuel Cap
Last Post: Maaske75
0 How stock is your bike
0 Keith Black Conversion
Last Post: Scuba10jdl
0 Question on a transfer valve
Last Post: Tator
0 New England 2018
0 2004 custom
Last Post: wongjohnson
0 Quarter turn throttle tube
Last Post: Kejobe
Last Post: kmul
0 Issues with threads on some colony parts
Last Post: DirtyHarry68
Last Post: TT60
5 Favourite grips?
0 Searching for a used Ironhead, my observations
0 Sportster tachometer wiring question
Last Post: Doc308
0 09 Buell XB12 crank
0 ***DK Custom-Limited Time 10% Savings on Rock-it Shift For Sportsters***
0 What color are your pipes?
0 Front brake shorting?
Last Post: Hughieboy
0 ***DK Custom-Limited Time 10% Savings on HALF-MOON FLOORBOARDS***
jdhickm (83), Chip (70), Chief4x4 (68), willyobiker (66), CBryant (65), XLCH69 (62), sage (59), VettesRule (56), jerseyjeff (56), TheExecutioner (53), SalTheWop (53), manic_mechanic, pauldmedic16 (44), BluegrassXL (40), Superman
Old 29th October 2009
twinfiend's Avatar
twinfiend twinfiend is offline
Sportster/Buell Year: 84
Other Motorcycle Model: GSXR 1000
Other Motorcycle Year: 05
twinfiend is an unknown quantity at this point
Default shock swap for an 84
Are there any other shocks from another model or brand that will swap over fairly easy to an 84? I'm most interested in something that would drop it some. Ill post some pics as soon as i mke enough post.
twinfiend's Avatar
[IMG][/IMG][IMG][/IMG]
There you go. Struts are just for mock up of ride height. If I can't find shocks that will work I'll machine some struts and run a mini shock seat.
einheit 13's Avatar
einheit 13 einheit 13 is offline
Senior Master Bike Builder
Sportster/Buell Model #2: 883/1200 Hugger
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to all
as long as the mount holes are the same diameter and the shock body isn't too big, you could use any length you want.....
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Shocks from most any newer Sportster will fit, but the lower bushings will be a little too wide to fit between the shock mounts on the swingarm. If you have the old stock shocks, just press the bushings out and install them in the new shocks. EBay is a good source. I think Nightster/Iron shocks are about 11" eye to eye, and there are tons of 11-1/2" shocks on there.
