Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 New From CA
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
Last Post: felis
Last Post: Skwerly
Old 29th October 2009
tocino tocino is offline
Other Motorcycle Model: Moto Guzzi 850-T
tocino is an unknown quantity at this point
Default Tighten head bearings on a '77
Hello all,
I looked in my factory manual and couldn't find where it described snugging up the head bearings. I'm getting a clunk feel that tells me they're loose. Going by the following pic:
Do I just loosen pinch bolt #2 and the lower fork pinch bolts and then snug up #22 ("sleeve end, fork stem")? Do I remove #22 and then tighten #21 ("sleeve, fork stem")? Something else?
I'd didn't want to go messing things up so I thought I'd check with the gurus here before I mangled some threads
Also, in this parts manual page it looks like #22 is below the upper triple-tree, but on mine it is on top. Is this right? Maybe the PO used an extra one as a replacement for 41/42 and I can't see the real one until I remove it?
thanks for the help
-Steve
If it is clunking I would disassemble it and check for damage, good chance the bearings or races are wrecked. I'll bet that if you tighten #21 the steering will feel notchy and bind up at certain spots.
I have had this clunk on my IronHead, and a Yamaha Virago some years ago. I just did as you have outlined and it was fine after that in both cases. Just have to have any pinch bolts loosened then snug it up; then retighten the pinch bolts, eh.
The bars, when straight ahead with the bike not doing anything, should tip from center to either side with a nudge.
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Very small amounts of tightening make a big difference. It's really easy to overtighten if you're not careful.
So it's tighten #21 to snug the bearings? What is nut #22 for?
runingmouse's Avatar
runingmouse runingmouse is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Sprint ss
Other Motorcycle Year: 1967
runingmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura about
That's the part catalog. I hope you have a FSM. HD # 99484-78
In the FSM it's on 2-26 removing fork stem ect. You'll most likely want to check the bearings.
then 2-30 tell's how to Install.
Thanks - I'll look again. (I have both parts cat and a manual (maybe just the 77?), I put up the image from the parts catalog for the ease of explanation)
Gone Gone is offline
just be real careful and dont tighten them at all beyond just getting the play out. too tight headset bearings will cause a highspeed wobble, or tankslapper, and trust me, you dont want to experience that on the freeway with a bunch of cages on your ass.
Old 30th October 2009
Thanks - exactly where you said it was. Guess I got impatient / lazy and didn't read through the chapter.
