0 What's Wrong With My Bike
Last Post: PoodlePunche
0 Need Correct K & N Filter #
Last Post: SportsterXLCH1967
0 [B][I]Most embarrassing bike moments[/I][/B]
0 Newbie here!
5 Mick Off Line
Last Post: randy3934
0 winding idle up excessively to start bike.
0 Calling all "Long Frame" riders...
Last Post: Jeff
0 time will tell, but...... (blacked out: fad?)
0 2021 Harley sportster 48 front fork cover and gaiter install HELP!
0 Pushrods Won't Hold Adjustment
Last Post: IronHeadRon
0 Engine tapping noise
Last Post: onadraw
0 Rebuilding and Tuning a S&S GBL carburetor
Last Post: thefrenchowl
0 trans door ?
Last Post: rocketnorton
Last Post: oldschool
0 Greetings from Dead Moanes..er Des Moines
0 Any old helmet users?
0 Pawl spring or shifter?
9 Knock heard and felt through handle bars
Last Post: XL_1200C
0 Aermacchi Parts
Last Post: Bigshankhank
Last Post: Texas78028
Closed Thread
Old 1st November 2009
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Post All things Carburetor- Tuning, Jetting, How-To Sticky Index
If you missed it on the Sticky Home Page, this thread is considered by many to be the "be all, end all" of tuning explanations:
Read this First - Jetting 101
These threads deal with the process of reading Spark Plugs as a diagnostic tool when tuning:
Plug Reading 101
Carb basics and jetting by reading the plugs
These threads have lots of technical 'nuts and bolts' information about working on Sportster carbs:
carb adjusting- Where are the jets and the mixture screw?
Jetting the CV carb for Dummies
The idle drop method of adjusting the CV carb idle mixture
Intake And Exhaust Leaks Tests
CV Carb Mod to Reduce Carb Farts
Audio and Video of CV Carb Diaphragm- Good and Bad
CV Carb Diaphragm install tip
CV Needle Drawings and Database
Carb Comparison on a Dyno
Why is my 92' 883 overheating?
Replacing the Enrichener (Choke) assembly
E-Z Choke Knob Removal & New Knob Install
How To replace Intake Manifold Seals
Secrets of the Dynojet Kit Revealed
Idle Mixture Needle Mod
Fuel fitting on carb
These are Mikuni specific threads:
Mikuni - HRS Carb Tuning Manual - From GWCRIM
MikuniHSR REAL WORLD tuning tips for beginners
Closed Thread
