0 05 and 73
Last Post: N8DIESEL
Last Post: The Crusher
0 If you have European tilt
0 Tool Roll Help
Last Post: RökkenRöll
Last Post: blindfredy
0 S.Fla. shop
Last Post: the cowboy way
Last Post: Moon Wolf
0 Back in Sporty Land
Last Post: skien
0 WTF Happened
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The country store
Last Post: lugster
Last Post: Xl-1250r
Last Post: jcro61
Last Post: Titaniumrust
Last Post: screndname
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 79 ironhead
0 2016 48 Hesitating
Last Post: 201648Rider
Old 5th November 2009
gene431 gene431 is offline
Sportster/Buell Model: xl883
gene431 is an unknown quantity at this point
Default Need help with sideplate
I just got some rigid sideplates & low sissybar off ebay an tried to install the sideplates but I don't have enough room between the fender an the side an my fender has a reflector on it if jack the bike up will it give me more room but the reflector will still be in the way.
pquirk's Avatar
pquirk pquirk is offline
Sportster/Buell Model: 883 XLC
Other Motorcycle Model: FXDWG
pquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant future
Remove the reflector with some WD40 and fishing line. Put some masking tape on the fender to protect it before trying to slide the side plate in or you might scratch the paint.
And now, for something completely different.....
