0 Manifold Leaks Gone !!!!
Last Post: cazz1000
Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Last Post: x1_guy
0 Masking stripes
Last Post: shooterj2003
0 no rear brake light
0 2016 48 Hesitating
0 Ei
Old 6th December 2004
spade spade is offline
Sportster/Buell Model: XL883C
spade has disabled reputation
Default Front tire sizes
I am about to change tires (I think I am going to go with the ME880.) For the rear I am going to fit a 140/90. I am not sure about the front. I know stock size is an 80/90. Is there any benefit in upgrading to a 90/90? Is handling worse or better? Any opinions/ ideas? Thanks.
sportymark's Avatar
sportymark sportymark is offline
Other Motorcycle Model: Yamaha XJR1300
sportymark is an unknown quantity at this point
Best stick with stock sizes, there is usually no advantage to upgrading (apart from a style issue) and sometimes it can upset the geometry of the bike, making it "tip" into corners more.
1200RSC - Roadster Sport Custom (Roadster Base, Sport suspension, SE Stage 2 engine and Custom bodywork)
"This man is depriving a village somewhere of an idiot"!
Old 7th December 2004
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
A lot better handling with the 90/90 21 size.........
(even better if you slip the fork tubes up the triple tree a little)
Similar Threads
Thinkin bout a fat front tire. 55 Jr Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 6 12th June 2005 09:24
Front Wheel / Tire size eagle Rubber Mount Sportster Motorcycle Talk (2004-2006) 1 26th March 2005 22:59
Whitewall front tire provision Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 4 17th March 2005 16:24
Front Tire Width dmraco Sportster Motorcycle General Discussion and Problems 12 11th January 2005 16:03
