0 Oil??
0 Rear tire
0 Salutations y'all
Last Post: cotton1
0 Show your tank decals
Last Post: cotton1
0 What's your helmet?
Last Post: cotton1
0 New England 2018
Last Post: joes95bobber
Last Post: cotton1
Last Post: RKN
0 Decman's Birtday
Last Post: Heff
0 67 Sportster build
Last Post: ldurmon
0 ##Dark side Tracker##Cam's ID?
Last Post: olddude13
Last Post: r4fthrs
Old 9th November 2009
1982ironhead's Avatar
1982ironhead 1982ironhead is offline
Bike Builder
Sportster/Buell Model: xlh1000
Sportster/Buell Year: 1982
Other Motorcycle Model: Triumph
Other Motorcycle Year: 196x
1982ironhead is on a distinguished road1982ironhead is on a distinguished road
Default assemble new engine out of frame, and reinstall as a whole?
its a fact, those rear head bolts are a bit(h to torque so since i have mine compleatly stripped right now i thought, well why not fully assemble and torque it to spec out of frame, then reinstall as a whole? you had to pull the engine to reach the oil pump on early models, would this be doable on an 82?
einheit 13's Avatar
einheit 13 einheit 13 is offline
Senior Master Bike Builder
Sportster/Buell Model #2: 883/1200 Hugger
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to all
yep, how do you think the factory put the bikes together?? thats how I did mine. I have also done them in the frame and forgot about the rear head space issue on my buddy's 75. So I just unbolted the motor and leaned it out of the frame enough to install the rear rocker box....Its harder to put it in as a unit if you do it like I do everything...floor level...no stand or table for the bike. I'm short enough (5'7") that it doesn't bother me to stoop down...lol...
Ivan RoachCoach's Avatar
Banned
Default Do it whichever way works best for you --- there's no rule...
...that says you HAVE to assemble it from the bottom end up, inside the frame.
I personally believe it makes a lot more sense to do it the way you propose, as it makes proper torquing of all fasteners possible.
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Here's a photo from 1979 at the York Plant of about 1000 assembled motors ready to be installed:
the cowboy way's Avatar
the cowboy way the cowboy way is offline
Sportster/Buell Model: hand built M/XL ironhead
Sportster/Buell Year: 9293
Sportster/Buell Model #2: 1976 motor in a 1987 fram
Sportster/Buell Year #2: ????
Other Motorcycle Model: 1974 XL & 2003 FXD
Other Motorcycle Year: 7403
the cowboy way has disabled reputation
Default not me
any time I build a IRONHEAD
I will install the cases w/ the flywheel assembly and oil pump only
it is too easy to scratch up the paint YOU AINT THE MOTOR CO
you aint got all those fancy tools on a assembly line
I then build the cam gear box and tranny in the frame
its the cowboy way
Forever Two Wheels
1997 AMRA National E-class Champion
Ironhead parts I have tons of em
machine shop @ home
Campsurf's Avatar
Campsurf Campsurf is offline
Sportster/Buell Year: 1970
Other Motorcycle Model: Triumphs
Other Motorcycle Year: 1964
Campsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the rough
I installed mine without cylinders or heads and was able to lift the engine right into the frame. I doubt I could have done it with the barrels on it.. I use blocks of wood to hold the cylinder square to the piston.. be sure to use rags so nothing falls into the bottom end. Keep everything that can fall in .. away from the engine.. believe me.. washers and nuts jump right in there !! I was recently doing an exhaust on a GMC 4x4.. and the damn exhaust bolt slipped into the exhaust .. I had to take the whole exhaust off to get it out.. magnets don't work...
The other thing is you are going to have to re-torque the head bolt once you have the engine running. For the past 20 yrs I have never torqued my head bolts... practice with a torque wrench and get the feel of 65 lbs... I use a long 12 point wrench with a one inch bend in it to tighten them down..
Putting the heads after the engine is installed is a great way to go.. it only takes an hour (if you have done it before) or two (if you have never done it) to install the heads..
Also when I remove the heads, I leave the Valve Covers attached if I wasn't having a problem with the gasket.. this save some time.. I can usually replace a head gasket in less than an hour..
Mine is a 1970
Jim
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1957
Other Motorcycle Model: KH KHK XLH XLCH
Moon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant future
Works either way. I prefer to assemble the motor and then stick it in the frame, but I usually leave the timing gears out. No special reason, but since I have the bike on the stand, it seems a little more convenient. It is a little harder to torque the heads with the motor in the frame, but as Jim says, a lot of guys (myself included) don't usually use a torque wrench anyway.
Sportster/Buell Year: 1972
I've found that laying the engine on the cam cover side on an old tire for padding. Then lower the frame over the engine. If the frame is freshly painted, wrap some type of padding around tight clearance parts of the frame.
Old 10th November 2009
Bike Builder
im not worried about it, flat black spray can is all it is, easy touchup!
rascalion's Avatar
rascalion rascalion is offline
Sportster/Buell Model: iron head
Sportster/Buell Year: 73
Sportster/Buell Model #2: xl
Sportster/Buell Year #2: 74
Other Motorcycle Model: 8ball-enfield-shovelhead+
Other Motorcycle Year: 07
rascalion is on a distinguished roadrascalion is on a distinguished road
done it most ways metioned here,,, by myself the easiest way for me is layin the frame over the engine on it's side like buckiryder said.
