Last Post: Vohnsen
0 New in NM
Last Post: Zoharo
0 C.O.B.B run west
Last Post: Zoharo
0 Kickstand identification?
Last Post: cotton1
Last Post: Vohnsen
Last Post: sltm1
0 What's your helmet?
Last Post: Wharfcreek
0 04 sportster custom 883, turn signal module (TSM)
0 Silverado Power lock issues
Old 9th November 2009
The Outpatient's Avatar
The Outpatient The Outpatient is offline
Sportster/Buell Model: 2005 1200C
The Outpatient has disabled reputation
Default My exhaust fell off while up on a moutain.
Well it didn't fall off but... The 2 Nuts that hold the front pipe on the cylinder head fell off. So I took one of the Nuts from the back 2 and plopped it on up front to get home. Got home and the other Nut from the back fell off so basically I rode with 1 out of 4 nuts/bolts.... arghh !
Anyway. Went to the hardware store to get some bolts and I got 4 that don't really look like the Flanged bolt that was originally on there. I think they are lock nuts. Got 2 extra and I'll be throwing some good tools in my tool bag just in case. Didn't have good tools out on the mountain so I couldn't tighten the 1 solo back nut while on the mountain.
1. Quess I should go to the dealer and get the right Nuts or bolts ?
( Whatever you call them, Nuts or Bolts ?)
2. Do You Guys use locktite on these ?
3 . Service book says to tighten these to around 100 lbs ?
Seems kinda to tight and I don't think I can get my torgue wrench in there tighten those bolts.
bigjnsa's Avatar
bigjnsa bigjnsa is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: BMW R1150R
bigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to all
Whoa dude, 100 lbs? I hope you mean INCH lbs.. 100 lbs would definitely strip those suckers right off. Mine are just standard 1/2" nuts that I tighten snuggly.
The heat temps would be too high for Loctite. A good way to check is if you see at least 3 threads on the end, you're good to go.
Personally, I check them periodically and tighten them if need be.
aka - 'Bubba' of the Hells Beerguts MC
When we ask for advice, we are usually looking for an accomplice.
Marquis de la Grange (1639 - 1692)
[SIGPIC][/SIGPIC]
wandrur's Avatar
wandrur wandrur is offline
Thx for the help, jackass
Sportster/Buell Model: XL 883 > SE 1200
Sportster/Buell Model #2: 1200 XLH
Sportster/Buell Year #2: 1999
wandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond repute
Nuts. Bolts are shafts, nuts have holes.
Most loctite won't hold up to the head at the cylinder head. I do think there's some high-temp stuff, but I'm not sure it's really worthwhile since I think it really cements the nuts.
100 lbs sounds waaaaay high. Make sure you're looking at the proper spec.
I would suggest double nutting if you've got the space on the exhaust stud.
EDIT: I see bigjnsa beat me to some of those responses.
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
Having just had the same thing happen to me I have to replace two nuts as well. I have standard nuts on now so I can ride, but will get flanged nuts when I get to the dealer.
They are a fine thread, make sure you get the right ones or you will bugger up the stud and be replacing it as well. The hardware store will most likely call them a 5/16th inch nut since that is the size of the hole in the center, so the size is a 5/16th fine thread. They will take a 1/2 inch wrench. To be safe, anyone with a parts manual can look them up in the back under fasteners.
Don't think locknuts will cut it. Most of the ones I have seen have some form of plastic that serves to lock the nut in place. Not sure what will happen when subjected to the exhaust heat, but I cannot imaging it won't melt. And if it melts I doubt it will be pretty.
Lastly, I do not recall the torque value, but it is most certainly less than 100 ft lbs. Screw Loose Dan pulled his cylinder studs out tightening his head bolts up to 120 ft lbs. Perhaps 100 in lbs, but look it up in the service manual, and then double check the torque wrench is the same scale as the bool. And then check again before tightening.
John Wayne - "The Shootist"
Good info.
These lock " Nuts " ( thanks for clarifying ) have no plastic in them but I think I'll go to the dealer and get the correct flanged ones and yes they are fine thread. They probably won't stand up to heat like the flanged ones. Didn't think about that. Only cost 2$ so...
Yeah 100lbs seemed a bit much. I made them snug. I'm not gonna worry about the lock tite and just periodically check them bolts. It's a Harly dang it, things come loose !!
This was a good lesson in bringing the right tools. When I put the Nuts on I took the tools I used and the extra nuts and stuck them in my Licks Solo Bag just in case. Love that bag.
Thanks guys.
Tin Man 2's Avatar
Tin Man 2 Tin Man 2 is offline
Sportster/Buell Model #2: XL1200, 2003
Other Motorcycle Model: Suzuki T250 Hustler
Other Motorcycle Year: 1971
Tin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond repute
There is a type of lock nut made out of all metal, I suggest anyone changing out pipes search out and buy these nuts before doing the job. I would think a manufacturer would include these nuts with the new exhaust system when you buy it. I would imagine a top line manufacturer like Remus would include the proper hardware, But your typical Harley noise maker supplier probably dont.
konel1's Avatar
konel1 konel1 is offline
Sportster/Buell Model #2: 1000XLCH IH Chopper
Sportster/Buell Year #2: 1977
konel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of lightkonel1 is a glorious beacon of light
There are lock nuts out there that have a small indention in the side of it which distorts the nut just enough to hold it in place.Sometimes referred to as stop nuts.It almost feels like the wrong thread when you start tightening it but they hold really well.You can probably pick them up at a parts store or bolt company. The type with the plastic is an elastic lock nut which does'nt last long with the heat.
sportyblue sportyblue is offline
Sportster/Buell Model: N/A
Sportster/Buell Year: N/A
Sportster/Buell Model #2: 01 Sporty XLCH
Other Motorcycle Model: 07 Dyna Street Bob
sportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond reputesportyblue has a reputation beyond repute
Here's what I did when my bolts starting coming out of my exhaust.......on the Dalton Hwy between Fairbanks Alaska and the Arctic Circle......no Harley shops there....had to get back to Fairbanks. That baby was dragging on the ground.......
Now that's why some people don't like to ride behind Harleys........loosing to many nuts and bolts, lights, exhaust,......never heard of loosing a fender yet though......:roflbla ck
konel1's Avatar
Been there done that more than once myself.Never hurts to have a roll or piece of tie wire with you wherever you go!
Robotech's Avatar
Robotech Robotech is offline
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 2011
Robotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to beholdRobotech is a splendid one to behold
For loctite you could try using a small amount of hi-temp RTV. It will hold up to the heat, should dampen the vibration that makes the nuts come loose, but shouldn't make it impossible to get them off later. Just a thought. I've never tried it but maybe I will if I ever take those nuts off.
1999 XL883, 1200 conversion...rebuilding time now.
2011 Dyna Wide Glide...stock...for a while.
aka Dirty Troy of Satan's Barbers MC
"why pay someone to screw something up when you can do it yourself for free?"
