0 Cartridge Conversion?
0 How do you upshift?
Last Post: Sprtstr1200s
0 Photo Gallery for XL Forum Team Members!
0 This Week in my Shop
0 48 Handling
Last Post: Thyratron
Last Post: squekster
0 Error B2116 & 2117
Last Post: tester
5 To Hone Jugs if replace Piston Rings?
Last Post: groovemeisterus
0 79 starter housing torque values
0 Oil line routing on an 80
Old 10th November 2009
n9pxm's Avatar
n9pxm n9pxm is offline
Sportster/Buell Model: 883 hugger
Other Motorcycle Model: honda cb750 chopper
Other Motorcycle Year: 1974
n9pxm is an unknown quantity at this point
Default oil leaking from breather on a 1995 883 sportster. will it stop?
here is the problem the best i can word it, i have an excess of oil leaking from my air breather. from what i understand oil bypass in the top end is directed into the breather to be "recycled" or burned instead of dripping onto the ground as in days of old. i am getting a build up of oil in between the jugs as the oil leaks out of the breather instead of being burned or sucked back into the carb. anyone have some solutions? thanks for your time.
life is a highway
Texas_Wild's Avatar
Texas_Wild Texas_Wild is offline
Sportster/Buell Model: 1st EVO - 883 - DEAD
Sportster/Buell Year: 1986
Sportster/Buell Model #2: Maybe some day a 1200
Other Motorcycle Model: Suzuki Bandit S 1200
Texas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enough
So its not comming from the manafold (front right side of motor)? If so that normally has it's own filter or a tube running back and under the bike!
That is normal (from what I know, which is very little) but it happens to mine too!
Learn something new everyday and your brain won't turn to mush! :tour
My 86 has passed and it was a sad day! I will ride again but not soon enought!
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Where, EXACTLY is the oil coming from?
It sounds like excess oil at the breathers...
What is the level of the oil in the tank when hot?
Try running it lower....anywhere on the low side of the range ought to stop excessive oil from coming out of the breather...assuming no actual problems...
~Chuck
Occam's Razor...
XLF Tuning Stickies
Fordson's Avatar
Fordson Fordson is offline
Sportster/Buell Model: 883/1200r
Other Motorcycle Model: Many
Fordson is on a distinguished roadFordson is on a distinguished roadFordson is on a distinguished road
Gotta be you cause the "factory" would NEVER sell a product with such a problem for year after year.
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
The heads breath into the air cleaner from the factory for EPA reasons. The two bolts holding your air cleaner to the heads are the breather bolts. Inside the head are umbrella valves which are little rubber valves which help to separate the oil vapors from the air. Some oil droplets will exit the breather bolts with the intended path into the carb intake which is then burned off in the engine. The umbrella seals tend to wear out and need replaced after several years. You will need to replace those. Another option is to get a head breather kit (even the dealer sells one) and install which then directs the oil mist to the ground. One thing I would do for sure is run a compression test and leak down test on the engine if the blowby is excessive to rule out internal engine issues.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Urrell's Avatar
Urrell Urrell is offline
Other Motorcycle Model: Electra Glide Ultra Class
Other Motorcycle Year: 2009
Urrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of light
Originally Posted by bykerbrad View Post
well said.. How many times are we going to have to answere this same question
He's only been on the Forum less than a month and it's the first time he's asked that question.
Would it not be better to point him in the direction of the search function if you cannot help
PS: The google search at the bottom of the page is better than the search function at the top for most things
linkin5's Avatar
linkin5 linkin5 is offline
Other Motorcycle Model: Honda XL 125
Other Motorcycle Year: 1982
linkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nice
It has been answered already but lower your oil level a little or just wait and it will do it by it's self. It is normal for an oily mist to enter the breather but if the bike if past half way up the dip stick is hen you'll see an excess there.
stm's Avatar
stm stm is offline
stm is an unknown quantity at this point
What about oil coming out of the oil tank at the filler cap? Already lowered the oil level that had been overfilled at my 5000 mile service.
Shu's Avatar
Shu Shu is offline
Poor piston ring to cylinder seal increases blowby which increases the amount of air/oil coing out of the head breather bolts. Also if the umbrella seals are getting bad they will allow more to escape.
Urrell's Avatar
I feel all better now
And so you should
