Last Post: xLoneRiderx
0 Happy Birthday Folkie!!!
Last Post: ronccc
Last Post: Brad
0 Headlight Modulator
0 V Stacks
0 Your Favorite Style
Last Post: Maxwell#256
3 Ironhead Pictures Thread
Last Post: Dirt Road Cowboy
Last Post: maltesefalcon
Last Post: thecarfarmer
0 Crank position sensor problems ??
Last Post: bobberman66
0 V.o.e.s
0 Windage Tray
Last Post: Blacky
0 Starter Worked, Then It Didn't
Last Post: flthd31
0 Rear Shock length '81
Last Post: Scar55
0 Home Brewing
Last Post: gravydog
0 This place still sucks!!!
0 Coil suggestions please!!!
0 My '05 1200C (insert clever title here)
Last Post: Ranchero50
0 05 sportster custom and bassani road rage
0 2009 Iron 883 Wont Start!
0 Rear sprockets
Last Post: 85IRONDIRT
kav2ivan (61), Hunt (54), bikerjim67 (54), twenty2 (42), slimstyle05 (41), PatrickSwayz (35), Mwaggoner
fitment, sportster, tank
Old 13th November 2009
beardedsk8er's Avatar
beardedsk8er beardedsk8er is offline
Sportster/Buell Model: Sportster Custom 1200
beardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enough
Default Sporty tank fitment
Does anyone know what the deal is on the fuel tank fitment for '86-'03 Sportys?
I was told one of the changes was in '95, what's the difference?
Are the factory 883 and 1200s, for most years, basically the same tank? I've also heard differnt people give me all number of different capacity for the same tank. Some people say stock is 2.25 gallon, some say 2.4. There's also a 3.3 which I think came stock on some years.
I see a lot of tanks being advertized as "sportster/bobber" tanks but when I ask if it'll work as a replacement for my tank I'm being told no.
Also, isn't it relatively easy to make any tank work on any bike? I assume the length will affect where the mounting brackets should be and where the seat stops. Appreciate if someone knows or knows where to find this info.
Peg Scraper's Avatar
Peg Scraper Peg Scraper is offline
Peg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of lightPeg Scraper is a glorious beacon of light
No change for 95' that I know of. Wait petcock changed from right to left.
Tanks fit 82' to 03'.
82' to 94' petcock right.
95' to 03' petcock left.
97' to 03' came factory with a 3.2 smooth king.
04' and up models require a 04' up tank.
If tank is not listed to fit a 2004-up model - rear tank mount will need to be modified / fabricated to fit your bike.
Standard tanks can run from the stock that came on bike 2.25gal to 2.4gal for after market.
King tanks can run from 3.1 to 3.3.
Here's a link for 94' XLH1200's gas tanks at J&P
http://www.jpcycles.com/search/searc...ll&results=100
My stock tank 2.25gal's
My King tank smooth bottom 3.3gal's
Both for comparison.
You can see that the king is longer, look at the rear mount. Also is wider & taller.
King fits snug to the seat and even crunches it in a little.
zenfrogmaster's Avatar
zenfrogmaster zenfrogmaster is offline
Sportster/Buell Model: Buell Cyclone M2
Sportster/Buell Model #2: Cafe Sportster
Sportster/Buell Year #2: 2000
Other Motorcycle Model: 883 Sportster
Other Motorcycle Year: 2002
zenfrogmaster is on a distinguished roadzenfrogmaster is on a distinguished roadzenfrogmaster is on a distinguished roadzenfrogmaster is on a distinguished roadzenfrogmaster is on a distinguished road
In 1995 they changed the size of the filler neck - I have two OEM 2.25 tanks, manufactured just months apart, and they use different size caps. The other consideration is the location of the petcock. The ones I have are on the left.
Ya I had remembered that and added to my post above.
In 95' when the petcock was moved to the left they also moved the ignition switch to the neck.
My bike is a 94' with a 95' tank on it.
Old 14th November 2009
wow, thanks for the info.
I didn't realize the 2.25 tank looked so small in comparison.
I guess mines 3.2. I was looking at my options for replacing it and was thinking of going with the 2.25.
Vanmor's Avatar
Vanmor Vanmor is offline
Sportster/Buell Model: Sportster 883/1200
Sportster/Buell Year: 1987
Other Motorcycle Model: Yamaha XV750 Virago
Other Motorcycle Year: 1982
Vanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura about
Beware of the tunnel width. I bought an older Sporty tank to put on my 87' and the tunnel was too small.
Vance
Do you remember what year tank you bought?
Also, does anyone know of any aftermarket tanks that have the old school shape you see on a lot of the hardtails. Its a more rounded shape that would fit my stock mount locations?
Something like these.
Available at J&P.
Or Mini mustang gas tank / Peanut gas tank.
Paughco® Mini Mustang Gas Tank
Part Number: 721-185
• This small gas tank looks awesome• Great lines, and only 16-1/2″ long, 9″ wide
• The Narrow tank has a capacity of 2.4 gallons with tunnel measuring 2-1/4″ wide x 2-1/2″ deep and front/rear mount tabs
• Total length tab center to tab center is 17″
• Tanks has 2, 1/4″ NPT petcock outlets
Note: This item is a custom fit component, and does not have any direct standard/OEM model application. Some items may require modification and an advanced level of mechanical skill and/or knowledge for installation.
Part Number: 721-186
•The Frisco tank has a capacity of 2.2 gallons and features a frisco style front mount
• Tunnel measures 3″ wide x 1-1/2″ deep, and total length tab center to tab center is 15-1/2″
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
I think tanks from '82 - '03 have the same mounting locations. The mounting ears are different when they went to rubber mounting grommets - maybe in 1995, so the holes are larger. As stated earlier, the petcock migrated from one side to the other, and the larger 3.3 tank won't work with some seats.
