Last Post: BluBeaSSt
Last Post: jcro61
0 90 in. Build
Last Post: mac93
Last Post: 883openpipes
0 New England 2018
0 Forty-Eight Special and Iron 1200 Sportsters announced today
0 Sportster or Street Bob
Last Post: seagullplayer
Last Post: conv90
Last Post: hscic
Old 10th June 2007
devilswild66's Avatar
devilswild66 devilswild66 is offline
devilswild66 is on a distinguished roaddevilswild66 is on a distinguished road
Default "Rear" Master Cylinder
Rear Master Cylinder Woes could there be a service bullentins:
I just put on a new rear tire and did not mess with the rear cailper (MoCo manual says you do not have to remove the rear caliper). After getting it all together and set up my rear brake quit working. So I tried to bleed the hydraulic system to no avil it did not work. I just disassembled the master cylinder and found the "PISTON SPRING" through the "PRIMARY CUP". Great...now I have to wait for the dealer to get parts in (I have to order) (Just-in-time inventory is just great ).
Matt
Mesa, AZ
2004 Sporty 1200 Custom
Old 10th June 2007
chrishajer's Avatar
Sportster/Buell Year: 1988
No bulletin or recall for the rear master cylinder that I know of. Most of the problems I see with the rear brakes, after a pad or tire change, are due to not getting the pins and pads installed properly on assembly.
http://www.xlforum.net/vbportal/foru...ostcount770026
That doesn't explain what you found in the master cylinder, but changing the rear tire didn't cause the problem in your master cylinder I don't think. If you didn't pull the caliper or the pins, I don't see what could be wrong back there either.
--Chris
Old 10th June 2007
Hot Rod Sporty's Avatar
Hot Rod Sporty Hot Rod Sporty is offline
Hot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud of
I took my 05 in for a spongy rear brake, and they first said that I needed new brake pads (at 7500 miles). When they put it up on the lift, the rear brake master cylinder was bad and they replaced it (under warranty). They never told me exactly what was wrong with it.
________________________________________
PROUD MEMBER OF THE 'IGNORED BY '79' CLUB :banana __________________________________
[SIZE="1"][B]RIP James "Mr. Jimi" Melton - 1947-2008
Godspeed brother.[/B]
[B]"Dream as if you'll live forever. Live as if you'll die today."[/B] --James Dean
[B]"A narcissist is someone better looking than you are."[/B] --Gore Vidal
[B]"I just love the 'mechanicalness' of it"[/B]
--Indian Larry Desmedt[/SIZE]
Old 10th June 2007
chrishajer's Avatar
That would make three that needed repair then, all of the sudden (that I have heard of anyway). CBAS5 just had one replaced too. Not sure what's going on there ...
--Chris
Old 11th June 2007
Here is a picture of the torn cup...
Old 11th June 2007
chrishajer's Avatar
That's pretty crazy. Good picture
Any idea how it happened? Were there any pieces missing from it that would have caused something like this?
--Chris
Old 11th June 2007
All the major pieces are in the picture. Above the primary cup you will see the center section which is a nipple that goes into the piston spring. The last piece is just above the nipple (center section of the primary cup) which is 0.100" x 0.050" x 0.050" in size.
--Chris
I want to "believe" that I felt something different with the brake pedal about one to two months ago, but the brake had been function just fine by stopping the bike. When I pulled the piston spring out of the master cylinder the cup was through the first couple of loops on the spring.
Old 11th June 2007
chrishajer's Avatar
That's definitely weird. Maybe you did feel something, but we all try to piece together things to make the explanation work. I've never had one of those master cylinders apart which is why I didn't know if all the piece were there.
It almost seems like a piece between the cup and spring is missing, or that something is missing off the end of the spring?
--Chris
Old 11th June 2007
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
I had problems with my rear brake for awhile before I took it in. However, mine was more obvious. I would lose brake pressure and then regain it as I rode the bike. Did you see any pieces of something in your brake fluid? I had orange globs in mine.
2005 XL1200C
Those who trade liberty for security have neither.
Old 11th June 2007
--Chris
I got a new picture that might give better details (3 pics in 1).
CBAS5
I will flush out the system once I rebuild the master cylinder and there is no since in cleaning out the system untill the new kit arrives. I could have globes of stuff in my lines which will get flushed in do time...and my guess is this rebuild kit will not get here till Thursday.
