Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
  #71
Old 2nd May 2010
hooptygoo's Avatar
hooptygoo hooptygoo is offline
Sportster/Buell Model: XL1200CSDSPC
Sportster/Buell Model #2: Ducati HyperMoto 1100 S
Other Motorcycle Model: GPz 750 - sold to Chica
Other Motorcycle Year: 1982
hooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to all
The belt isn't that heavy. What would it be knocking out of adjustment?
XL 1200 Custom Super Duper Sport Poser Cruiser (sold)
2009 Ducati Hypermotard S ("S" is for Superhero)
Old 30th August 2010
papadad's Avatar
papadad papadad is offline
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1956
papadad is a name known to allpapadad is a name known to allpapadad is a name known to allpapadad is a name known to allpapadad is a name known to allpapadad is a name known to allpapadad is a name known to allpapadad is a name known to allpapadad is a name known to allpapadad is a name known to allpapadad is a name known to all
on the 04-up, is it a kit (spring and cap) or do you need to buy a hole cartridge like on the evo rear brake system
pvlittrell's Avatar
pvlittrell pvlittrell is offline
pvlittrell is an unknown quantity at this point
Default It's a kit
It's a kit. All the guts that go in the tube.
04 1200 Roadster - Screaming Eagle II Pipes and Air
Old 10th April 2011
matridge's Avatar
matridge matridge is offline
Sportster/Buell Model: 883c
matridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura about
i had the problem described with the m/c , but i hadnt messed with tire or caliper or brakes at all for about 7 months maybe. just went out while on a ride. no resistence when pushing brake. im about to disassemble now.
Old 30th May 2011
wedge's Avatar
wedge wedge is offline
Originally Posted by 883+ View Post
every rubbermount I see with this problem was because of a tire change or removing the shocks letting the belt slam down on the linkage right where it turns to go into the master cyl.
It shows up while changing a tire, but there is no connection. I recently spoke to someone who is an engineer for that MC. What seems to happen is that the primary cup gets torn in the center and it manages to still work as long as the MC is not disturbed much because it is backed up with that flat metal plunger which helps it seal even tho broken. Then they are a bit of a bitch to bleed, but with a broken cup they won't bleed anyway.
Those of you who have done the job will note that the new cup has a tit on it that goes into the center hole of the washer that is welded to the end of that spring. Well when the parts are new the problem doesn't seem evident, but if you take the broken cup and the spring/washer thing and hold them together on the bench you will see that the washer can slide sideways quite a bit within the center of the primary cup. I think that the tapered spring tries to cock some every time the pedal is pressed causing it to work against that tit until it breaks the tit off and leaves a split across the cup. I think the better cure would be to put a larger washer on the end of the spring so that it will not keep fighting the tit for centering. I sent a detailed explanation of this to the person I spoke too, but did not get a reply yet.
Bleeding is the other problem, and the big loop in the brake line is a possible cause for this (trap for air), and also some have said that the return hole in the MC is too small (I agree), but enlarging it is risky unless you can make sure that there is no burr left to hurt the new cup.
Old 3rd July 2014
MaNickles's Avatar
MaNickles MaNickles is offline
Sportster/Buell Model: XL1200C 2005
MaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of light
i have the same spongey brakes what is the part number i need to get the rebuild kit and do i need kit A or B i have a 05 1200C
Old 28th December 2014
Kayakeur's Avatar
Kayakeur Kayakeur is offline
Sportster/Buell Model: XL883C
Kayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of light
1. Question: Banjo bolt: installing new complete rear master cylinder. XL883C, 2005. Page 50-51, 05 Parts Catalog.
There is something inside the little hole in the shank of the old banjo bolt (part# 41736-04). Rubbery.
Is it supposed to be there? What is it?
I poked it with a probe to be sure it wasn't my imagination.
I was going to re-use the old banjo bolt but now I'm inclined to get a new one at dealer.
So: another 30 mile trip in the cage to HD Parts Counter to
Buy new Banjo Bolt part# 41736-04
Also buy: 2 sealing washers 10mm (part# 41732-04) for banjo bolt. Manual says discard them but complete mast cyl assy does not include them nor banjo. Old ones look ok to re-use but they are up close and personal with brakes & I'm going to HD anyway & they cost less than my co-pay insurance.
Also buy: new retaining ring, part# 11031 (circlip) for shoulder bolt (part 94432-04) on bell crank. Manual says discard old one but it is not included in new complete mast cyl assy 42521-04. Old one looks ok but you cannot tell if it is still springy and it's part of what makes the brakes work, so buying new one.
btw Manuel says discard 2 hose clamps (part# 10252) on hose to reservoir. You get 2 new ones in Assy, keep old ones on the old reservoir & hose, give to an indigent loner passing through.
Kayakeur Dec 2014
2. EASY BLEEDING: Use a SpeedBleeder (speedbleeder.com). Works absolutely great. It's a one-way valve, so air cannot get sucked back through it. It's a permanent replacement for the OEM bleeder valve. Just screw the old one out, screw in the new one per their instructions. Don't worry about air getting in as you screw old one out; you're going to bleed anyway. Most useful on rear tire but cheap enough, $7 each I also put one on front tire.
How much you back it off from full tight makes a difference, you may have to turn it plus or minus a quarter turn from prescribed half-turn. Get their transparent silicone bleeder hose/tubing, too, 30" $3. Get their hose even if you've got some tubing already because it fits perfectly, nonreactive to brake fluid. Re-usable, store it in ziplock bag, you'll need it again when the master cylinder craps out again in 10,000 miles. Get their bleeder bag $3 to collect the purged fluid - eliminates spills, neat & clean. Re-usable. When bleeding route the hose upward from bleed valve and then loop down to collection bag / can / bottle. That makes it easy to see air coming out - you'll see tiny bubbles slowly rise to high point of hose. You can bleed alone with Speedbleeders, you will not need a second person! Get 'em for your cage, too.
Old 18th May 2015
Grumpy-Biker's Avatar
Grumpy-Biker Grumpy-Biker is offline
Sportster/Buell Model: Custom 883
Grumpy-Biker has disabled reputation
This is a great forum.
With the information in this thread and another I read I was able to rebuild a master cylinder for the first time. It took longer than a person with experience would require but it all went well and the brakes are performing so much smoother.
Thank you posters for all your precise information.
j
j
Old 18th May 2015
rejeanprimeau's Avatar
I've TIG welded the washer hole and cut the tit and no more problem. When you push back on the caliper's piston to enter it to install your wheel it's at that moment when you disturb or tear the cup, I always open my bleeder so as not to push the rubber cup back ward, not a single tear since opening up the caliper bleeder. Also a good oppertunity to flush your brake fluid; change tire, change fluid and check pads.
Old 18th May 2015
I tied a rope to the brake pedal and ran it under the jack. It took about 40 pulls to bleed. I was thinking of installing a little pulley on the jack but didn't really need it. I usually work alone so I think a little differently.
